By the way, my door microswitch stopped working a long time ago (no door, dome or interior light when I open it) but my problem with the lock was just recent. I think it's safe to rule out the microswitch as the problem? |
im also encountering this problem, were you able to find a solution? thanks
I am having a hard time opening my drivers side door from both inside and outside only after unlocking it, whether I use the key fob, the inside door unlock switch or the door key cylinder. I have to give the outside door handle a gentle hit/bop before I can open it. Please note this only happens when I unlock the door. After the initial unlocking, I can open and close the door repetitively without any problems. That is until I lock it again! Seems like my door latch does not completely unlock? Any help/suggestion/advise would be greatly appreciated! |
Sounds like the plunger in the micro-switch assembly is failing, probably a wear issue, but possibly dirt or something. Possibly even a mounting adjustment. There's a pic, of the assembly opened up, around here somewhere. I think maybe MarvinsDad put it up.
Here are some good links - http://forums.vwvortex.com/showthread.php?1542461 http://api.viglink.com/api/click?for...13141784707651 The complete assembly is available here http://api.viglink.com/api/click?for...13141785094534 Thanks to Smileybug for the links and parts rsource! MORAV
In der Automobil-Scheune '02 NBT, A/T, Moonroof, Platinum Gray, Flannel Gray Leather Interior (Currently on the slab in the morgue, possible ressurection in the offing) '05 NB Convertible, Tip 6sd, Dark Flint Gray Edition, Garnet Red Top, Bordeaux Red Leather Interior '01 Corvette Convertible, Magnetic Red, Light Oak Top, Light Oak Leather Interior '96 Suburban LT 2500, 454BB, Summit White, Neutral Leather Interior '95 Camaro Z28 Convertible, Polo Green, Black Top, Tan Leather Interior Last edited by MyOtherRidesAVette; 08-24-2011 at 09:36 AM.. |
| Tags |
| door lock , latch |
| Driver's door not shutting properly | CoriBug | Questions, Issues, Concerns, or Problems with the New Beetle | 10 | 04-06-2010 01:24 AM |
| drivers door hard to open | SEABEECM1 | Technical Modifications | 3 | 11-30-2009 10:40 PM |
| Driver's door won't lock | freecellwizard | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 12-31-2008 07:34 PM |
| Funky driver's door | bonnie | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 04-08-2007 04:26 AM |
| Driver's Side Door Problem | matone_05 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 02-25-2007 07:11 PM |
