STICKY 5th GEAR - NewBeetle.org Forums
Old 05-25-2010, 02:31 AM
giink's Avatar
Pelham, NH, USA
Car: 2000 VW Beetle 2.0L (AEG)
Default STICKY 5th GEAR
My wife was driving the Beetle today and said she had trouble shifting into 5th gear? Said it felt like 5th gear felt "locked" and couldn't go into it after 4th.
Any ideas or thoughts??????????
Old 05-25-2010, 02:46 AM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
david, my man...couple things.
first off, cable adjustment. try that, see how that does you. search youtube for "02j transmission adjustment".
second is a gear lube change. it's definitely not a lifetime fluid. i change mine every 60k.
Old 05-25-2010, 02:48 AM
killerbeetle's Avatar
Bronx, Ny, NY, USA
Car: 2002 Vw beetle 2.0 GLS
Question
It might be your transmission oil, if not it;s best to have it checked by a professional. You should test drive it to be sure, maybe your wife wasn't pressing the clutch all the way in when shifting?
Old 05-25-2010, 02:59 AM
The Cheat's Avatar
or the cable adjustment is off.
i see it all the time on these cars, in fact when i get a stick in for a major service, i usually align them free of charge because it's that easy.
Old 05-25-2010, 03:03 AM
giink's Avatar
Pelham, NH, USA
W@W! Those were quick answers! I'll check the fluid first and then I'd check the adjustment... if I knew how?
Old 05-25-2010, 03:04 AM
giink's Avatar
Pelham, NH, USA
Duh... just saw your Youtube advice, The Cheat!
Old 05-25-2010, 03:08 AM
giink's Avatar
Pelham, NH, USA
Unhappy
Went on Youtube but wasn't able to find any instruction for the transmission adjustment?
Old 05-25-2010, 04:07 AM
Pierce County, WA, USA
Car: 2000 GL
Does it do this often? Could it have been a driver error?
Old 05-25-2010, 05:05 AM
DZLBUG's Avatar
Big Stig
Sauk Rapids, MN, USA
YouTube - Volkswagen Group Shift Linkage Adjustment for year models 2000-2010
2000 New Beetle GLS TDI
Old 05-27-2010, 03:18 AM
giink's Avatar
Pelham, NH, USA
Default Thanks Again For All Your Help!
Thanks to everyone. Clean the linkage under the air filter box... lot of gunk buildup and now she runs fine!
David
5th gear mod? sean_fabanich Transmission Talk 3 04-10-2010 05:03 AM
TDI 5th Gear swap? Beltaine Transmission Talk 2 11-30-2009 06:29 PM
Trouble Shifting into 5th Gear! Help beetlejuice27 Transmission Talk 5 06-17-2009 06:49 PM
5th gear swap on my 1999 2.0 teeroy Transmission Talk 13 08-05-2008 09:08 PM
Hard to get into 5th gear, 30 miles later, no gears! nebben Transmission Talk 12 05-23-2007 08:51 AM
