Let me start by saying -- I am no mechanic. I work in Computers and junk. But I know how to turn a wrench and I'm wiling to try. But the biggest motivation is I didn't want to pay $500, or $800, or whatever it cost to have it done.
1) So the first thing I did was to jack the car up and put it on jack stands - be safe. 2) The next thing is to remove the plastic under-tray and then the oil pan steel guard if you have one. It was like 2 or 3 bolts. 3) Now remove the oil pan. There are 3 sideways bolts that hold it to the tranny or whatever it is and like 20 hex/allen head bolts that old the oil pan to the bottom of the engine. Once all the bolts are removed the oil pan should just come right off. Check all around to make sure you didn't miss any. If it won't come off, tap it gently on the side with a rubber mallet to break the seal. In the pictures below, on the left is a side-by side of the two oil pans. The stock aluminum one and the new super cool black steel bottom pan. On the right is a close-up of the threads on the stock aluminum oil pan. As you can see they are really jacked up. Last edited by High Mileage Bug; 05-25-2010 at 03:03 AM.. |
Here is a close up picture of the plug in the new oil pan.
The left picture is the outside of the plug and the right picture is the inside of the plug. Notice that the plug is in the steel part of the pan. This pan should not strip as easily as the aluminum pan and last for the rest of the life of the car. |
4) Next I put the gasket sealant goop all around the top lip of the new oil pan.
5) Put the oil pan up to the bottom of the car and put in the 20 hex/allen head bolts. Tighten until snug but don't over tighten. 6) Put in the 3 sideways bolts that holds the pan to the transmission (or whatever it is). 7) Put the oil pan guard back on then the undertray. 8) replace the oil filter, wait a few hours for the gasket goop to cure, then fill with oil and you're ready to go. Important -- watch for leaks for the next few days - especially on the first day. Watch the oil level carefully. Check it regularly for the first while. If the gasket doesn't seal 100% or if the pan is not on right or not tight enough (for goodness sake don't overtighten the bolts) then it might leak. Just keep an eye on it. Last edited by High Mileage Bug; 05-25-2010 at 03:00 AM.. |
It took about an hour to 90 minutes to remove the old pan -- about 15 minutes of scraping and cleaning off the old gasket seal -- and about an hour to 90 minutes to install the new oil pan.
Total cost: $100 - new steel oil pan plus shipping $13 - tube of automotive gasket sealant $15 - 5 quart jug of motor oil $6 - new oil filter. It really wasn't that bad. If you're patient and take your time you should be ok. It's not that difficult to reach all the bolts. There are 3 that are a bit tricky because they are recessed but if you use a long allen wrench (that what I used) you can get them out then back in. I changed this about two weeks ago and so far no issues. No leaks, the driveway it perfectly clean and the oil level is holding steady. Let me know if you have comments or questions. |
Nice work.
I really disliked those three hidden tranny bolts; I used a 5mm ball end hex wrench; worked like a charm and the bolt size is 10mm.
My NB Family... |
My mechanic just fixes stripped VW oil pans by putting a steel 1/2" drain plug from NAPA in the stripped hole. They thread in hard the first time obviously and then seal tight. I'd recommend trying this before pulling your pan.
I changed my oil pan a few months ago for the same reason and I too used the steel bottomed pan shown. For about $100, I got the pan with free shipping, no tax, new oil pick-up and a tube of VWs liquid gasket material. The job takes o more than an hour or so from start to finish. I got it from GermanAutoParts.com. Here's the link if needed.
GermanAutoParts.com I did use one of those larger oil plugs from the auto parts store but over time, it too started to leak. This is a permenent fix and it's fairly cheap. Extremely cheap if you compare it to what a dealer would charge.
- Joe ![]() 2001 Techno Blue Pearl 5 spd GLS. Heated leather, fog lights, power sunroof, alloy wheels. |
| Oil Plug Stripped ! | Daisey | 2.0 Liter Gas | 56 | 09-18-2010 03:52 AM |
| Stripped Oil Drain Plug | jrw2scw | 2.0 Liter Gas | 11 | 01-22-2010 06:29 PM |
| Oil pan (stripped) - my options ??? | Cadenza | Questions, Issues, Concerns, or Problems with the New Beetle | 10 | 04-09-2009 12:36 PM |
| Oil Drain Plug Stripped? | kimberinthecity | 1.9 Liter TDI | 20 | 09-16-2008 08:14 PM |
| oil pan plug | oldceltjohn | 2.0 Liter Gas | 1 | 01-19-2006 07:01 PM |
