I understand that many forum members believe that the unusual consumption of oil in our 1999 VW Beetle GLS with a 2.0L engine was a fault of VW by assembling piston rings backwards (upside down).
Can anyone please assist in recommending what parts should be changed if the drastic step of removing & opening up our model engine to stop the oil burning is taken. Also knowing if we should use the OEM parts, and if not, who to get improved after market parts from is appreciated. (always having to check the engine oil & refill it is for the birds) Thank you. |
here's a solution: mobil1 15w50 exteended with the m1-301 filter. my car's down to a quart every 5k instead of every 1k.
change every 20k. ps: the car holds a full 5qt with the 301.
My situation is like many others on the posts, have to put about 1/4 of a quart every 1 - 2 weeks depending upon how much I drive the bug. I was going to use 40W oil at next change but am targeting fixing this problem once and for all.
New piston rings seem to be on the parts list prior to opening it up, but aren't the "oil guides" also a recommended part to change if oil consumption is the problem? Car only has about 53K miles on it & drives/idles fine. I was not thinking I'd need to hone the piston wells but am no expert either. Big job & I agree that midas well chanage other parts once it's opened up. |
unless you live south of the mason-dixon, 15w50 is safe all year-round.
my car started in -10 weather this winter with no issues. 15w50 is thicker, protects better, and reduces blow-by. |
For those of us at the Mason Dixon or below, what are your recommendations?
Rodney: 200k 5/18/09 "Running Down a Dream" by Tom Petty on the radio (00 2.0 auto black) Electra: 01 TDI Manual Silver Arrow Wrecked 10/24/09 Monty: 98 TDI Manual Silver Arrow VIN 010385 Home 11/24/09 |
i know a buddy in little mexico (arizona) who runs 10w60 year-round in his tdi, the car needs it cruising at 120* ambient temps for 6 hours plus at a time. to the op: this is how i combatted the initial loss in fuel consumption; i aired my tires to 40 psi, cleaned all the crap out of the car, and basically kept the car in tune. right now, i'm pushing 34mpg easily. sure, my lifters are a hair noisier at startup, but it's a vw with 8 valves, lifter tick is expected and appreciated (i'm an mk1/2 guy at heart). |
| beetle piston rings | sparktikus | 2.0 Liter Gas | 11 | 04-02-2009 04:16 PM |
| Engine Removal, 2000 GLS Turbo | Turbosl2 | 1.8 Liter Turbo | 5 | 10-07-2007 09:25 PM |
| FS: Aluminum Dimpled Defrost Rings + Fan Rings | bugness | Market Place Archives | 6 | 09-14-2007 01:44 AM |
| 1999 new beetls GLS engine noise | anstoss | 2.0 Liter Gas | 11 | 04-29-2007 05:04 AM |
| '02 Beelte GLS - Major Engine Problem! | albertoflores3 | Questions, Issues, Concerns, or Problems with the New Beetle | 9 | 03-22-2007 12:43 AM |
