what's your average MPG and RPM when cursing around 60mph - NewBeetle.org Forums
Old 05-25-2010, 06:43 PM
Question what's your average MPG and RPM when cruising around 60mph
what's your average MPG and RPM when cruising around 60mph ish
mine RPM almost hit 3000 when cursing at 60mph ish... is that too high? and my MPG is never higher than 24MPG. (60% city, 40% HWY)
2000 NB 2.0L
Old 05-25-2010, 06:49 PM
middknight1's Avatar
LIVE FREE OR DIE!
San Diego, CA, USA
Car: 1999 GLS Beetle 2.0L 5 speed "Betty"
Originally Posted by progeek View Post
what's your average MPG and RPM when cursing around 60mph ish
mine RPM almost hit 3000 when cursing at 60mph ish... is that too high? and my MPG is normally higher than 12MPG. (60% city, 40% HWY)
2000 NB 2.0L
@75 mph tach is at about 3800ish with my style of driving (cruise at 80 to 85 depending on traffic) i avg about 25 mpg. (75% highway 25% city)
"Semper Fortis"
Old 05-25-2010, 07:10 PM
CoriBug's Avatar
over 120k miles in 7.5yrs
Fort Collins, CO, USA
cursing??
Old 05-25-2010, 07:16 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
at 60mph, my car turns 3000rpm.
it also pulls 34mpg.
air up the tires to 42psi, that makes a HUGE difference.
Old 05-25-2010, 07:29 PM
i just had #1 cylinder misfire reading from the OBD2 device. The technician checked out and turn the CEL off. Apparently it happened just once a while.
Will I notice the RPM change if the misfire happens again? Cheers.
Old 05-25-2010, 07:45 PM
Mr Maynard's Avatar
Beetle Loving Gamer
Swansea, IL, USA
Car: 2000 GLS
70%highway
30%city
Getting about 34MPG
My Tires are aired up too.
Not bad.
Old 05-25-2010, 07:47 PM
callisto9's Avatar
Good-bye Curby...
Bettendorf, IA, USA
Car: '08 Scion xB - "Artie"
Ooooooooooooooh, I'm going to pump mine up and see if that improves my MPG. Thanks for the tip.
My RPMs always seem high. I think that's how the Beetles run.
Me (Erin) ~ My car (Curby)
(o\_vw_/o) Beetles rule!
There's no apostrophe before an 's' when you're talking about the plural version of a word. "I took some neat photo's!" is NOT correct.
Old 05-25-2010, 08:11 PM
Originally Posted by Mr Maynard View Post
70%highway
30%city
Getting about 34MPG
Not bad.
how fast you run on highway?
Old 05-25-2010, 08:29 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
This thread may be of interest or maybe this thread...
My NB Family...
Old 05-25-2010, 10:37 PM
Mr Maynard's Avatar
Beetle Loving Gamer
Swansea, IL, USA
Car: 2000 GLS
Speed limit.. 60-65ish, Im also sluggish and take my time.
Old 05-26-2010, 12:47 AM
Canadianbugin's Avatar
Canadian New Member
Toronto, Ontario, Canada
Car: 98 N.B. 2L 5speed
Interesting logs... What i find very interesting is the difference between the 99 AEG and the 98 AEG.. Did you ever find out what the tranny codes are in these cars. Should both be o2J no ?? Why i say this is there is 300 rpms difference between the two and only 1 KPH difference in speed...
Old 05-27-2010, 12:51 PM
D2Beetle's Avatar
NB Yellow Trifecta
I did and the '98 and '99 are the same code initially, but I found out that there is transmission sub-code which I still need to get; i.e. so an accurate tranny code is actually six digits 02J 1VB. Something to add to my holiday weekend to-do list as I'll be working on both.
Old 06-01-2010, 05:43 PM
You can always turbo it
WI, USA
My usual MPG is about 19 city and 28 highway, with aftermarket parts, however at 65 MPH, my car runs at about 4200 RPMs, 4 speed auto
vDubOne Project
2001 2.0L NB GLS
Dyno: (stock) 122HP
Dyno: (2010) 186HP
13.695 quarter (2009)
Old 06-01-2010, 09:34 PM
Pierce County, WA, USA
Car: 2000 GL
Honestly, I just drove through the mountains on a 4 hour drive each way this weekend. I filled up the tank, I only used half a tank of gas going each way.
The total mileage is 235 miles, I was averaging between 31-33 MPG, I actually used less gas coming back.
First big trip the car went on and it "crushed" my g/f's Chevy Cobalt up hills, and in overall mileage.
So much for newer being better! TBH, the comparison wasnt even close. She was averaging 28.7-29.4 MPG.
Clearly the Beet wins this battle. Sorry average speed was 75 because the speed limits are 70
Old 06-01-2010, 10:28 PM
jstargell34's Avatar
Calhoun, GA, USA
Car: 1999 VW Beetle GLS 2.0
I went 300 miles on 13.6 gallons of gas. I was getting 380 miles per fill up. I havent changed my driving habits,but I did put an 02 sensor spacer on the front 02 sensor, because another beetle driver said he got better gas mileage when he installed his spacer and now I have an check engine light for the front sensor and he doesn't, We both have a 99 beetle 2.0 automatic, whats up with that?
Old 09-01-2010, 12:12 AM
Chucktastic's Avatar
Im bigger than you
Virginia Beach, VA, USA
Car: 2003 Beetle GLS, 2.0L, Auto
Even after getting the work done a few weeks ago, Im still getting crappy mpg #'s
Hoped getting the timing belt, thermostat and water pump changed (water pump failed) it would help with the low mpg Im getting.
Right now getting around 220-230 per tank. This is mostly around town driving with some interstates on the weekend but just short 10 miles trips.
Was worried about the RPMs too since it just 'sounds' high. Have an auto 2.0 and around 65-67mph Im doing 3200 rpms. Also seems like I have power left to go. If I stomp down to pass someone Im does drop a gear/downshift and jumps easily into the mid 5000. Will take a video of it tomorrow if anyone wants to see it.
Does that sound right? I will check my tire pressure on Thursday when I fill up (before Earl comes to town). But I check that from time to time and its never really been that far off.
Anything else to check to help with mpg?
Old 09-01-2010, 02:45 PM
D2Beetle's Avatar
NB Yellow Trifecta
Your rpms are on the money for a 2.0 AEG, even if it is an auto. If your NB is operating properly you should get somewhere in the neighborhood of 320-420 a tank. The downshift and rpm rise is normal for the event you describe.
You might want to check this Speed/RPM chart. Yours should fall somewhere between the '98 and '99.
Old 09-02-2010, 02:07 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
...but just short 10 miles trips...
That will kill your average mpg, the gearbox oil is hardly warm after that much less up to proper temperature, likewise the engine will spend most of that mileage warming up so nothing lubricant-wise from engine through to wheel bearings is at proper, low friction temperature...
Cheers
Simon
Old 09-02-2010, 05:09 AM
Im bigger than you
Sorry for the confusion, didn't mean to imply just a 10 mile trip. I meant just 10 miles of interstate driving each weekend. Not even sure that was even important information at this point.
Car is already warmed up from stop/go normal street driving prior to getting on the interstate, then when i get off its back to normal street driving. Only mentioned the interstate due to the higher than normal rps I thought I was experienced.
Old 09-02-2010, 07:11 AM
DarkFlint's Avatar
Red Top & Red Seats
Raleigh, NC, USA
Car: 2005 New Beetle Convertible 2.0 GLS Dark Flint Edition
2000 NB 2.0L
My beetle rpm is ~2700 at 60 mph and I normally drive 300 mpg / full tank (city and highway).
From my long distance trip in August, my beetle used 1/2 tank for 250 mpg (60 mph, highway only).
Average life of the 1.8T? Audiophil 1.8 Liter Turbo 8 12-10-2008 06:02 PM
FS : 2002 NB GLS TDI Diesel Average 40 Mpg Automatic. Ralphb Market Place Archives 1 12-30-2006 04:18 PM
How many rpm's at 60mph? juhvelo 2.0 Liter Gas 14 02-10-2006 06:06 PM
Help: Steering / Front end shimmy over 60mph? Buggin Questions, Issues, Concerns, or Problems with the New Beetle 2 12-19-2005 07:16 AM
Performance - 0 to 60mph versus mods roamerr 1.8 Liter Turbo 11 12-10-2005 10:24 PM
