bucking - NewBeetle.org Forums
Old 05-29-2010, 02:23 AM
Default bucking
check engine light is on when i put my foot into the gas pedal the car will start to buck and the check engine lite will flash. the obd2 test say that cylinder #4 missfire. checked the plus and wire they look ok any thoughts
thanks
jim cav
Old 05-29-2010, 02:42 AM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
thanks
jim cav
1, Get it scanned by a VagCOM, Vw's specific code scanner that pulls Vw and Audi Codes.
2, Have you replaced the Spark Plugs and Coilpacks? If you have a 1.8T, the coilpacks can be changed at your local Vw Dealership for free.
3, Welcome to the org!
Old 05-29-2010, 03:09 AM
digitalputty's Avatar
Where is home ....
Lone Tree, Greeley, USA
Car: 2003.5 GLS BLCC (Zoomer)
Totally sounds like coils.
Welcome to the .org!
J'veux pas mourir tout seule.
Old 05-29-2010, 03:16 AM
dnyed's Avatar
Portland, USA, USA
Car: 2002 New Beetle 1.8T GLX
Coil packs! It happened to me!
Former VWs:
2003 NB TDI - Galactic Blue
2005 NBC 1.8T- Tornado Red
2003 NB Turbo S - UniRed
Currently:
Old 05-29-2010, 05:19 AM
Default bucking
this is a 1998 it has a distributor. the other day it set out to change the plugs started with the one on the left looking into the engine compartment. autozone sold me autolights after removing the plug seen that they were ngk figured i would return the autolites and get the better plugs this is when this all started. plug wired are seated good dont know what else to check?
Old 05-29-2010, 07:03 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
OK, do you have the old plugs? One thing would be to put those back in and see if it clears. The other point I would make is that the wires can be damaged by pulling on the wire when you remove them instead of the boot itself.
They can look fine but still be defective.
Change plugs (replace the originals for now)
Change the wires
Change the coil pack (what looks like a distributor)
Cheers
Simon
Old 05-29-2010, 07:11 AM
No it doesn't
Old 05-29-2010, 10:39 AM
simonsi's Avatar
Jitterbug
Car: 2000 NB 2.0
No it doesn't
No it doesn't but it does have a single coil pack and HT plug wires, it does NOT have coil packs like the 1.8T and isn't part of the recall.
Old 05-29-2010, 03:41 PM
Duh
Really bad bucking around 3500 RPM eliteboi 1.8 Liter Turbo 6 03-22-2010 10:39 PM
Constant slight bucking... help? MisterTurbonium 1.8 Liter Turbo 12 09-11-2009 07:10 PM
