Please some help/
My AC does not work i Checked as much as i can but there is no power at the compressor. I do not think i can continue without some sort of wiring diagram. There is power at the switch and the switch is working but at the compressor none anyone know where i could get a diagram |
I did not read that thread until now. My brother is the one doing the work for me and i know he used a voltmeter I do not know if he tested resistance. From what i gathered from watching him was we bought the Chilton book and it said to pull off the relay under the hook and jump pins 1 and 2 to engage the clutch. My brother said both pins 1&2 had no voltage so jumping them would do nothing. He then looked at a wire diagram and said we needed to find the control module but we could not located it and my brother being 6'7 tall and this being a beetle did not work well together. What steps should i tell him to take |
guys i have read the thread you all suggest and i am baffaled
i get no voltage at the compressor and no voltage off the fan control relay but i have voltage at the switch in the car and i also have voltage going in to the module I replaced the module today (used) and same exact thing no a/c no power at compressor and if i jump it nothing happens i even went as far as to check if there was too much freon and that is not the case either could anyone help it is july in nyc and man its hot thanks nick |
| Electrical Please Help!! | FallinApartBoy | 1.8 Liter Turbo | 9 | 02-06-2009 07:29 PM |
| Electrical Issue | dducky007 | 1.8 Liter Turbo | 3 | 11-04-2008 02:36 AM |
| Electrical shut down? | Solscud007 | 1.8 Liter Turbo | 11 | 06-25-2008 02:57 AM |
| help with electrical?? | MandieGirl | Questions, Issues, Concerns, or Problems with the New Beetle | 5 | 05-22-2008 07:27 PM |
| Need electrical help?? | fatdaddy | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 01-24-2006 11:07 PM |
