Oh, nooooooo!!!!!! - Page 4 - NewBeetle.org Forums
  #61 (permalink)
Old 06-18-2010, 07:59 PM
sedwar05's Avatar
Prescott (pres-KIT) :o), AZ,
Car: Flutterbug- '98 GLS 5-sp 2.0
Wow, that hug must've really worked, I can almost feel the love...
- S
Flutterbug's Picture Thread:
http://newbeetle.org/forums/photos-n...gls-2-0-a.html
  #62 (permalink)
Old 06-18-2010, 09:29 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Originally Posted by sedwar05 View Post
wow, that hug must've really worked, i can almost feel the love...
lol!!! :d
Cheers
Simon
  #63 (permalink)
Old 06-19-2010, 12:43 AM
Canadianbugin's Avatar
Canadian New Member
Toronto, Ontario, Canada
Car: 98 N.B. 2L 5speed
Lol...
  #64 (permalink)
Old 06-19-2010, 03:23 PM
Pierce County, WA, USA
Car: 2000 GL
A/C and heating was a short course.
There was a bit of testing on the pressures, and they also covered diagnosis of the most common problems, example would be not allowing the system to burp long enough. Some other things we covered, ( I cant remember the term used 100% ) However, when coolant interacts overtime with solder, and what the affects and problems would be associated with that, also covered deposits such as scale build up. Difference in temperature in the upper & lower hose if there is a restriction, or other problems. Microwave test thermostats.
We also did dye tests, among other things for leaks. Pressure test caps, I already did a heater core, and water pump in class on a customers vehicle.
Went over thread sealants such as ( Super 300 ) for screws that may thread into water jackets etc... There was a quite a bit in the A/C & heating portion, it was just really short and crammed in.
Hugs or shots? I prefer shots...
  #65 (permalink)
Old 07-02-2010, 04:43 AM
JaceyMelissa's Avatar
Jace
MI, USA
Car: 2000 beetle 1.8turbo
any luck getting it fixed???????????????
  #66 (permalink)
Old 07-02-2010, 01:29 PM
sedwar05's Avatar
Yes,
It ended up being a fan control module, so we had that replaced and it's not giving any more overheat problems so far...
xx crosses fingers xx
Next month will be plugs/wires/coil pack, then she should be all good to go!
  #67 (permalink)
Old 07-02-2010, 08:22 PM
Canadian New Member
Yes,
Glad to hear everthing is still good...Let's hope it continues to behave...Unlike me lol...
  #68 (permalink)
Old 07-03-2010, 01:32 AM
I had replaced the head gasket, surfaced head, water pump, timing belt, thermostat etc. When I fired it up, it did not take long to overheat. I drained the water and noticed not much water come out. When I added water again, it did not take much. So I did what I had done years ago. I pulled the top radiator hose off at the head, filled the radiator through the top radiator hose until water run out of the outlet at the head, reinstalled hose, topped off the system, and now no more overheating. Run it for a while and added a little of water as needed. Now it runs normal temperature. If you run into a problem as this, this may help.
  #69 (permalink)
Old 07-04-2010, 05:57 PM
sedwar05's Avatar
Please don't jinx me, I have to drive down to the Valley this week and it's 118* there...
  #70 (permalink)
Old 07-04-2010, 08:17 PM
Canadian New Member
Oh no way....I am sure your NB will behave.. Drive safe and have fun... Oh and some more pictures would be cool too...
Nooooooo!!!! bugfreak Miscellaneous Hoo-Ha Archive 14 01-07-2006 04:43 PM
