http://newbeetle.org/forums/photos-o...eaks-down.html |
Trust me, when the previous owner complained of Oil Consumption, I noticed he was only using 5w30 valvoline dino oil. I DID step up to Mobil 1 5w40 and it got it down to 1/2 quart burn off. Thus switching over to Rotella T cheapened it and still has what it seems the same protection. BTW, WIX as a cheap filter? Oh they are WAY better then the Frams out there. Every vehicle Ive purchased only used WIX filter products. |
You could be getting more protection and better performance from your VW is all I am saying. |
Back to the original topic of this thread: I just put it back together again. This time I modified head for improved oiling to top end. Also installed a Bosch oil filter and 20-50W oil (engine has 145K miles). Now it is very quiet and smooth running. But the previous owner dumped alot of stop leak in it and I suspect the radiator is plugged up. The engine comes up to temperature but both radiator hoses are cold along with the radiator. For you info, the head has been surfaced, new head gasket and bolts, new water pump (with metal impeller), timing belt and pulleys. One question: how do you get the radiator out of this thing? It is a 2000 Beetle with a 2.0 AEG.
Thanks, Don |
| Evap Purge Valve/N80 Valve | BUGSTUFF | 2.0 Liter Gas | 6 | 03-17-2011 12:51 AM |
| Lifter installation - priming | vtirocz | 2.0 Liter Gas | 3 | 06-09-2009 02:14 AM |
| lifter ticking - possible solutions? | callisto9 | 2.0 Liter Gas | 22 | 06-17-2007 11:33 PM |
| Valve ticking noise | bluevwfan | 2.0 Liter Gas | 3 | 05-14-2007 03:19 PM |
| combie valve & N112 valve (vacuum lines)??? | marisagi | 1.8 Liter Turbo | 1 | 02-09-2006 11:53 AM |
