I just replaced the head gasket on a 2000 2.0 AEG engine. I changed the intake valves also. Now the engine has bad lifter noise when it is reved up, but not to noisy idling. It runs smooth but is noisy in the top end. Is there a fix or does it eventually go away?
Oil level good?
The only off the shelf one I can reccomend is the Castrol Syntec 0w30, it's 1 litre containers, and it's made in Germany. The following are the ones you can get away with *w30 and *w40 unless noted: The rest are Amsoil, Fuchs, Liqui-Moly, Motul, Redline, Schaeffers, and the Shell Rotella T6(5w40). Also, Oil Stabilizers are for goofs who think gear oil or boiler heating oil has a place inside an engine, and tries to supplement their use of improper oils such as non-synthetics/semi-synthetic. |
W-40 is not as much protection as W-40. Also be careful to see what conforms to VW 502 00, 504 00, 505 01, or 507 00 Oil Specifications for your car. The 4 lists are for different VWs so make sure you know which list applies to your car. Many of the oils on your list are not on VW's list. 502 00 and 505 01 are on the link below and are the ones that apply to my Passat for example. http://pics.tdiclub.com/data/500/vw_tb_17-05-04.pdf If you aren't checking your oil with these lists, you are taking big risks with the most important fluid in your car. |
You said you replaced the valves. You also said its noisy.
When you put brand new valves in it, did you have the valve seats machined? I think its 45 degree bottoming stone and a 30 degree topping stone? ( I might be a lil' off ) The valve face smacking the valve seats, could cause abnormal valve train noise. Is oil getting up to the valve train; Is your pick-up tube cloggged? |
I use K&N and have had no problems. but some good ones are purolator and wicks (or however they spell it). may I also suggest usind the diesel size filter. it has larger/better filtration capacity and it will allow your engine to old a little bit more oil.
Amsoil, Bosch, K&N, Mobil 1, or VW oil filters are what I recommend. Bosch makes the VW filters I believe. Purolator and Wix are no better than Fram.
I have never heard such alligations. I have always been told by my uncle/ a certified mechanic, numerous other mechanics that I trust, and the only guy at the auto parts store I trust (because he doesnt give a crap if you buy things at that store or a different place, he just helps you get what is the best) and they all said fram sucks, I think we all agree on that. but wix and purolator are very good/among the best filters according to all of them.
My .02
1.Wal Mart grab a large bottle and a separate quart of Rotella T 5w40 (18 bucks) 2.Goto O'Reilys Auto Parts and buy their brand of Oil filter which is a relabeled WIX (2 bucks) 3.While you're there, grab a new plug (1 buck) for extra insurance Then just head home, pop the radio on, crack a beer, and do an oil change. My Beetle LOVES Rotella T. Used it in my MK3 2.0 as well and it did very well. Burn off now went from 1 1/2 quarts on dino 5w30 to just 1/2 with Rotella T. Nice trade off! |
use either K&N, Mann, WIX, or Bosch.
Mann's are fairly cheap; here in Washington about 7-8 bux. K&N about 12-13 bux Wix about 6 bux Bosch about 7-8 bux. IMHO Bosch is the worst one of those 4 listed. Go with Mann, if not K&N |
them out! Thanks!
http://newbeetle.org/forums/photos-o...eaks-down.html |
should use anyway. Bosch is also the maker of the OEM VW filter so I am not sure why you don't like them... I do not use generic, one size fits all brands like Purolator, Fram, STP or Wix on the advice of lots of VW Mechanics and TDI Club Trusted Mechanics. The relatively small price difference is worth not taking the chance on such a special car as the Beetle in my opinion. |
(see post 12 above...lol)Last edited by Canadianbugin; 06-24-2010 at 05:36 AM.. |
| Evap Purge Valve/N80 Valve | BUGSTUFF | 2.0 Liter Gas | 6 | 03-17-2011 12:51 AM |
| Lifter installation - priming | vtirocz | 2.0 Liter Gas | 3 | 06-09-2009 02:14 AM |
| lifter ticking - possible solutions? | callisto9 | 2.0 Liter Gas | 22 | 06-17-2007 11:33 PM |
| Valve ticking noise | bluevwfan | 2.0 Liter Gas | 3 | 05-14-2007 03:19 PM |
| combie valve & N112 valve (vacuum lines)??? | marisagi | 1.8 Liter Turbo | 1 | 02-09-2006 11:53 AM |
