2001 New Beetle EPC, Limp, CEL - NewBeetle.org Forums
Old 06-25-2010, 02:57 PM
Default 2001 New Beetle EPC, Limp, CEL
Hello All, 2001 New Beetle 97000 AEG eng auto
Looking for some help sorting out a new problem with my 2001 NB. I have had a few problems lately that may or may not be related. First had a hard failure of the fuel pump. 2 second prime and start showed 12 volts but pump would not run. R&R pump and all,s well. By the way the pump gasket was a mess. the bottom edge sits in fuel and was falling apart into the tank. I had to clean the tank out.
Now, the current problem du-jour. after the pump all was well for days then i now after 10 min trip i get an intermittent EPC light and engine seems to misfire until after a couple of misfires turns the CEL on and car seems to run better. The codes are po321 po322. If i clear the codes engine will not start./ I can smell fuel when trying. Pull Battery and she will start right up.
Me thinks i have an ignition problem. Could the Crank senor be intermittent? I rang out at 538 Omh,s Could the cam sensor be intermittent? I am putting a new fuel filter on this weekend and i will cut the old one open. Looking at new plug and wire,s also as they are old although the wires look great.
Any ideas guys, thanks
Old 06-25-2010, 04:14 PM
Garage
From the Ross-Tech Wiki...
16705/P0321/000801 - Engine Speed Sensor (G28): Implausible Signal
Possible Symptoms
* Engine shuts off
* Engine doesn't start
* Speedometer inoperative
* Glow Plug Indicator Lamp (K29) flashes
Possible Causes
* Engine Speed Sensor (G28) loose
* Engine Speed Sensor (G28) faulty
Possible Solutions
* Check Engine Speed Sensor (G28)
16706/P0322/000802 - Engine Speed Sensor (G28): No Signal
Possible Symptoms
* Engine shuts off
Possible Causes
Possible Solutions
Old 06-25-2010, 04:46 PM
Regina, SK, Canada
Car: Yellow '98 Beetle AEG + 01M
Mine reading comprehension right in the morning is not the greatest...
Old 06-25-2010, 07:16 PM
Canadianbugin's Avatar
Canadian New Member
Toronto, Ontario, Canada
Car: 98 N.B. 2L 5speed
Lol.......You sure it's just in the morning....Lol...
Old 06-26-2010, 12:19 AM
Regina, SK, Canada
Pfft!
I assure you, I have rather good comprehension... Somedays though... I definantly make myself wonder...
Stupid battery... Stupid coil...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
EPC, CEL on QuanBlackBug Questions, Issues, Concerns, or Problems with the New Beetle 4 02-08-2015 06:04 PM
2001 Beetle EPC light is lit with multiple error codes singeljj 1.8 Liter Turbo 2 05-17-2010 08:37 AM
ESP on after start, EPC on sometimes, no CEL, why? AmazinglySmooth 1.8 Liter Turbo 7 03-25-2007 02:51 AM
EPC and CEL came on, yeah... jc918t 1.8 Liter Turbo 0 11-28-2006 05:50 AM
2001 Stopped Working CEL & EPC lights on zorb13 Questions, Issues, Concerns, or Problems with the New Beetle 0 10-15-2006 01:40 AM
