Speed Sensor Issue - NewBeetle.org Forums
Old 06-29-2010, 12:11 AM
giink's Avatar
Pelham, NH, USA
Car: 2000 VW Beetle 2.0L (AEG)
Default Speed Sensor Issue
Hi! I need to replace the Speed Sensor on my 2.0 Beetle 2000(manual trans). Has anyone here ever replaced it themselves? I'd like to know where it's located on the vehicle and also the degree of difficulty to install a new one.
Always appreciate the help!
Old 06-29-2010, 12:24 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Remove the SAI pump and follow the cable from the connector just to the left of the SAI pump connector. The sensor is located tucked in behind the oil cooler/filter mounting flange assembly. It is quite fiddly to get to...one allen bolt from memory IIRC
Cheers
Simon
16885 Vehicle Speed Sensor - Speedo Issue v12bug 1.8 Liter Turbo 7 10-18-2010 12:22 PM
2003 Speed sensor. phatmonk Transmission Talk 1 02-27-2010 07:56 PM
Speed Sensor?? ecollin1 Questions, Issues, Concerns, or Problems with the New Beetle 3 10-09-2008 07:24 PM
Speed Control Sensor rob11g 2.0 Liter Gas 1 04-01-2006 07:06 AM
speed sensor Help geeger 1.8 Liter Turbo 6 11-28-2005 12:48 PM
