OK here goes......
I had a couple threads with this problem but this is what is going on as of now I am a new VW beetle owner (99 gls) The a/c does not come on. The fans and blower work and air comes out all vents but the compressor never comes on I read all the threads you guys directed me too and i did a whole lot of test All of the fuses are good I tested voltage at a few spots at switch----yes at batter----yes going into FCM---yes coming out to compressor (from FCM ) NO at compressor----NO I jumped out compressor and nothing happens I changed the FCM and everything stayed the same but it was a used part so i guess it is possible to have 2 bad FCM but not likely. I tested the amount of refrigerant in the system and it is correct not too much. I am lost on what to do next any advice please please please thanks |
I actually responded to your other post. The used FCM that you tried, do you know for certain it is good?
Read this post and see if you can determine which A/C component setup you have and check them.
My NB Family... |
| Learning | Boggle90315 | New Member Forum | 0 | 01-10-2009 08:48 PM |
| Learning By Doing | geezerb | 1.9 Liter TDI | 0 | 07-31-2006 11:16 PM |
