OK, so I know this is not a MAJOR problem like I've been having, but yesterday at the gas station Flutterbug wigged out on me and would NOT open the fuel door when I flicked the door switch. I had to get a small flat head screwdriver and manually pop open the cover at the pump.
Has this happened to anyone else, and if so, what do I do to fix it? Thanks, - S
Flutterbug's Picture Thread: http://newbeetle.org/forums/photos-n...gls-2-0-a.html |
Yes. Typically, inside the car panels, there is an actuator with a cable attached to it, that is ran to the gas tank lid.
The actuator may not fail, but the cable likes to seize up, and not work anymore. It may start to get intermittent, and then it will just not work anymore. Not difficult to fix, it is time consuming because you have to remove a few body panels on the inside. It is located in the rear passenger side of the vehicle, and is tucked away behind the panels. If you can hear the actuator tugging and activating. Then it is the cable that is seized up. You also have to remove the rear tailight on the passenger side in order to properly run the cable. They just pop out. It cost me about 100 bux for both parts actuator and cable. |
Mine has been doing that lately. I just keep hitting the button until it pops. I'll fix it eventually, but when its 100+ degrees out everyday, right now just isn't a good time to tinker with my car
When i bought my '99 NB last September, that was one of the things that was not working. I also had to use a tool to get it open. Following the advice on this site, I took off the rear panel and located the cable. I just jiggled and played with it a bit, didn't want to take the whole thig apart and replace the cable. Now the fuel door will open if I push the button inside the car then stick my fingernail under the flap. That's fine with me for now. I need whatever $$ there is to repair more importnt things than that and If I can get it open, that's the importnt thing!
update: Just went out to the driveway to do a test on the release and after the 3rd try it poped open, so I guess I'm in the "intermittent stage" LOL Thanks for the info and help! - S |
Mine has never worked since i bought the car.. But I just open it with my finger nail.. Its not hard..
Mom and Daughter Journey Together with "Smurfette" 98 nB Metalic Blue 2.0 GL 5 speed.. Also proud owners of a 05 F150 4x4 husbands 99 mustang GT (built) |
| FINALLY!!!!!just picked up my 09 Beetle yesterday | jeromiej | Photos: New Beetles | 60 | 06-03-2010 09:43 PM |
| I bought a new beetle yesterday and didnt even make it home! Help! | britfred1987 | Questions, Issues, Concerns, or Problems with the New Beetle | 16 | 07-10-2009 05:44 PM |
| So... yesterday..... | antonym | Miscellaneous Hoo-Ha | 4 | 09-09-2008 05:44 PM |
| Guess what I got to see yesterday! | KatieBug27 | The New Beetle Experience | 1 | 04-25-2008 01:51 PM |
| what I got done yesterday. | gilligan | Styling Modifications | 13 | 02-09-2006 11:14 PM |
