My Daughter's Beetle has been sounding a bit loud, so we took it to the muffler shop. They said its either the Manifold or the gasket...
** Anyone have some advice on removing the Exhaust Manifold ?? ** Wondering how hard this is going to be ? I can get a used one from the junkyard and found the gaskets, so I just need some advice before I go jumping into this project..... |
You can find some used ones in junkyards, that are still in good shape for about 60-75 bux.
Otherwise, if your at all interested. You could always throw in a header and exhaust for the hell of it. ( I know it aint cheap, it's fun. Probably not logical ). Is it a loud "ticking" sound? |
Canadianbuggin,
Yes its a 1998 2.0 - Is there anything special I need to know about removing it or putting it back together ? The only thing in the way seems to be the heat sheild which I already had off for inspection. It appears I can get to all the bolts from the bottom. I didnt know how much of a pain its going to be. Did you drop the exhaust at all or just remove the maifold |
And it continues....
While looking at how to remove the exhaust manifold...found what I thought was a very small oil leak from the oil plug, upon a closer look the oil pan has a hairline crack on the bottom just in front of the plug. I will be ordering a steel bottom pan, and while Im at it do another transmission filter and gasket, fluid since its right there. |
Cheers Simon |
You may have a leak somewhere, but if your not getting a loud "ticking" sound, I would look elsewhere, then exhaust manifold gasket.
That is the most common noise you will hear in that case. |
The nuts on the manifold to downpipe flange are M10 x 1.5 Also, I would suggest replacing the exhaust manifold flange gasket. |
This is what I have lined up for repairs...
1) Exhaust Manifold - New gaskets,harware etc.. 2) New Oil pan with steel bottom 3) Oil Cooler O Ring - since I will be changing the oil pan,oil filter etc 4) Transmission filter,fluid etc- Ive done this before, fairly easy 5) Repairing a vacuum leak correctly- I just put tape over till now.... 6) Front Rotors - Already replaced the pads two weeks ago...might have caliper issue...find out when I get in there.. 7) Clean the motor with engine bright...so I can keep an eye out for any leaks... I think thats enough for one day. Im praying this will keep the Bug going for a while with no other issues.....geez... Later this year I will replace the oil cooler o-ring for prevenative maintanence Last edited by daughtersbeetle; 07-22-2010 at 05:51 AM.. |
I have a stud extractor,but you can use vise grips and if you need heat,a torch.. Wise to replace all the studs and gaskets. Also what i did,was to soak all the hardware you are removing with penetrant...
Alright heres the list and this is what was completed...
1)(Never got to it) Exhaust Manifold - New gaskets,harware etc.. 2)(Broke a bolt,but got it out,done) New Oil pan with steel bottom 3)(Done) Oil Cooler O Ring - since I will be changing the oil pan,oil filter etc 4)(Done) Transmission filter,fluid etc- Ive done this before, fairly easy 5) (broke the tubing..great)Repairing a vacuum leak correctly- I just put tape over till now.... Air Injection hose 6) (Didnt have time)Front Rotors - Already replaced the pads two weeks ago...might have caliper issue...find out when I get in there.. 7)(Done) Clean the motor with engine bright...so I can keep an eye out for any leaks... 8) (done) Aim Headlights 9)(Done) this is why I still have to do a couple more repairs.... While under the car, below the drivers door on the bottom of the car there are round rubber grommetts(WHY), one had fallen out so, the hole had become enlarged(great)....Repaired it with some sheet metal,3 sticks of JB weld,under body rubber spray... No more oil leaks...... |
| Exhaust joint leaking | fohveh | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 01-08-2010 10:03 PM |
| Cracked Exhaust Manifold | lalabug | 2.0 Liter Gas | 6 | 07-15-2009 03:38 AM |
| Newbie - question about manifold exhaust pipe | newfiebeetle | Questions, Issues, Concerns, or Problems with the New Beetle | 0 | 12-02-2008 02:06 AM |
| RTS exhaust manifold? | Eriksbug | 1.8 Liter Turbo | 0 | 05-13-2007 05:47 AM |
| exhaust manifold question | ktbug78 | Questions, Issues, Concerns, or Problems with the New Beetle | 9 | 02-09-2006 01:26 AM |
