How to replace the belt tensioner for the serpentine belt? - NewBeetle.org Forums
Old 07-09-2010, 02:02 AM
Milwaukee, WI, USA
Car: 1999 2.0L 5 speed 133K miles
Default How to replace the belt tensioner for the serpentine belt?
Today, as I was driving on the freeway my serpentine belt on my 1999 Beetle 2.0L 5 speed snapped.
I picked up a new belt and replaced it in about 5 minutes.
While I was replacing the belt, I noticed the roller on the belt tensioner was very stiff. I suspect that was the reason the belt snapped. I'm sure it froze for a moment while I was on the freeway and the rotation of the crank pulley burned right through the belt.
The new belt is doing fine and the tensioner roller was turning but I will not drive it tomorrow. Instead I will pick up a new belt tensioner/roller assembly and install it this weekend.
My question is: How difficult is it to change it? Does anyone have step-by-step instructions or know the link to a thread with this information?
Old 07-09-2010, 11:38 AM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
I wonder if the serpentine tensioner is the same on the 2000 1.8T; I'll take a look at Cowboy's this weekend. If it is I could do a DIY on it.
My NB Family...
Old 07-09-2010, 12:01 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
The tensioner is held onto the motor with 3 bolts. Its a real easy job, i don't remenber if you have to take anything else off first since its been a few years since I did a mk4 timing belt (its gotta come off for that).
Old 07-09-2010, 03:47 PM
Milwaukee, WI, USA
The pulley for the the tensioner only cost $15, where as the entire assembly is $70. So my question is, is it as easy to just change the pully? Is it just held on by a simple bolt or does it need a special tool or needs to be pressed on?
Old 07-09-2010, 07:38 PM
Toad's Avatar
Mableton, GA, USA
this picture shows that it looks to be held on with a t25 or t30ish looking torx screw? If it's that easy then i would do that instead of buying a whole new assembly.... but it looks like it might be a pain to get off
Old 07-10-2010, 01:22 AM
Milwaukee, WI, USA
Hey thanks, I just finished changing the pulley on the tensioner. I was extremely easy.
Serpentine Belt Tensioner Fix DavidBauder Technical Modifications 3 05-12-2011 10:58 AM
Loosen Serpentine Belt Tensioner. vdubing 2.0 Liter Gas 6 01-12-2010 04:58 PM
Serpentine belt?? prediger Questions, Issues, Concerns, or Problems with the New Beetle 5 04-09-2008 12:17 AM
Fs: New Nb Serpentine Belt $20 rccolors Market Place Archives 0 07-17-2007 09:03 PM
