I purchased my Timing belt kit from Blauparts for $135.00
I'm not knocking any others but the parts were quality parts, the services dept took care of you big time and the package arrived next day. It doesn't come with stretch bolts. Product Part Number: GH21100-B Product Information: Vw Beetle Timing Belt Kit Includes: OEM Quality TüV / ISO 9001 / TS16949 Certified Parts 1 Timing Belt 1 Timing Belt Tensioner 1 Heavy Duty Water Pump w/ Gasket O-Ring 1 Front Crank Seal (Viton Seal Material) 1 Camshaft Seal (Note: Cam seal does not fit vehicles with rare BBW engine code) 3 Liters G12 Plus German Antifreeze (2 - 1.5L Bottles) Appropriate amount for complete cooling system flush. 1 Thermostat Housing w/ Hose Clamp Blauparts' Vw Timing Belt Repair Guidelines / Tips 1 FREE Accessory Serpentine Belt 1 FREE Thermostat w/ O-Ring http://www.blauparts.com/proddetail....od=GH21100%2DB ![]() Last edited by mrathell; 07-26-2010 at 09:47 PM.. Reason: forgot something |
The water pump impeller is metal.
I installed this kit, minus the seals, a few weeks ago - worked out just fine. Also installed the new stretch bolt set from ECS Tuning |
Did you get this bolts kit from ECS Volkswagen New Beetle 2.0 > Search > Mount Bolt > ES#2201 Engine Mount Bolt Kit (Set Of Seven Bolts) - MK44CEMBS ? Is it the same as from dealer but cheaper. AFAIK there are only 2 stretch bolts? |
| Timing Belt kit for sale | wjbass80 | Parts and Accessories | 6 | 10-12-2008 03:47 AM |
| Timing Belt Kit Needed | David Bartlett | The Canada Corner | 4 | 04-16-2008 04:39 PM |
| '01 2.0 Beetle Timing belt kit | vtirocz | 2.0 Liter Gas | 3 | 02-24-2008 10:00 PM |
| bad water pump! need a timing belt kit! Who has a quality kit? Any recommendations? | billymade | 1.8 Liter Turbo | 7 | 02-11-2008 06:41 PM |
| Ordering Timing belt kit from U.S. | ttraina | The Canada Corner | 4 | 12-09-2006 01:18 PM |
