I STILL Can't Get It Out :( - NewBeetle.org Forums
Old 08-17-2010, 02:28 PM
Beetlescott's Avatar
USS ERNIE PRISE NCC 1701
LOUISVILLE, KY, USA
Default I STILL Can't Get It Out :(
I know I'm not mechanically inclined, but I thought sure I could get the radio out of Ernie!! I got the VW "tools" and did what the manual said, "It Should Slide Right Out" NOT. Can anyone help me out???
Old 08-18-2010, 06:32 PM
make sure the angled side on the tools are inward (toward radio) on both tools, then insert them and it will click into a groove and then you have to pull on both evenly. I had trouble on mine, but it definately slides out, but even tension on both sides helps. They gather dust and gunk around the radio and sometimes its hard to get out.
Old 08-18-2010, 06:44 PM
Blugg's Avatar
Alaska, United Kingdom
Car: 1.9 TDi Alaskan Green
Use this
YouTube - Volkswagen New Beetle Radio Removal
If you still can't get it out, i used a coat hanger shoved into the cd mouth and just Yanked that motha out
Old 08-19-2010, 02:30 AM
LOUISVILLE, KY, USA
Thanks, I'll give it another try tomorrow. I got the right side to move, but the left side wouldn't budge.
Old 08-19-2010, 02:52 AM
LOUISVILLE, KY, USA
Originally Posted by Blugg View Post
Use this
Thankss so much! That guy had something to pull on with those extra tools. I'll give it another try tomorrow!
Old 08-20-2010, 03:43 PM
LOUISVILLE, KY, USA
OK I followed the UTube demenstration and It slid out perfectly. I changed the fuse in the back, turned the radio on, and SAFE came on, and then it started playing!!!! I still have a problem with my cd changer though, it will work fine for a few minutes then stop and go to cd error.
Old 08-20-2010, 06:21 PM
Blugg's Avatar
Try vacuuming it out, probably just a bit of dirt in their somewhere
Old 08-31-2010, 06:58 PM
LOUISVILLE, KY, USA
You ARE joking, right? I'd try anything right now.
