My turn misfire p0304 - NewBeetle.org Forums
Old 08-26-2010, 05:48 AM
Default My turn misfire p0304
X
Old 08-26-2010, 06:06 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Perform the leak down test and let us know the results.
My NB Family...
Old 08-27-2010, 01:55 AM
X
Old 08-27-2010, 04:51 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Do you mean 12% on cyl 4? What was it on the others? by design the valve should rotate during use to even out wear, you may have a slightly out of round seat/valve such that in some position(s) it leaks more and some less, that may be why the issue comes and goes...
Cheers
Simon
Old 08-27-2010, 07:58 AM
4SEVEN3's Avatar
Blue ones are faster!
Greensboro, NC, USA
Car: 2004 GL Lagoon Blue
Before Id go all crazy, Id move the coil and plugs to different cylinders and see if the code follows either one of the parts. Say move the coil to #3 and plug to #1, drive and see what happens.
Another thing you might have going on is some carbon deposit on the seat. SeaFoam works awesome as does plain old water, adding it while the engine is running (numerous methods)....water reeks havoc on carbon and makes things shiny new!
4SEVEN3
4SEVEN3's Avatar
Greensboro, NC, USA
Please ignore double post.....
Old 09-11-2010, 08:54 AM
X
Old 09-13-2010, 08:44 PM
X
Old 09-13-2010, 11:33 PM
Where all have you looked? ECS tuning and Germanautoparts both have head gaskets for sale. ECS has a kit. GAP has the gasket and head bolts.
Old 09-14-2010, 07:44 AM
X
Old 09-14-2010, 02:51 PM
How long for the GAP parts? I've never had a problem getting parts from them quickly.
Old 09-14-2010, 11:01 PM
X
Old 09-28-2010, 06:22 AM
X
Code p0304 and nothing else santafeguy74 2.0 Liter Gas 3 07-01-2010 09:41 PM
Turn right, turn left - engine dies ?? Humbug Questions, Issues, Concerns, or Problems with the New Beetle 8 06-23-2010 08:50 PM
MIsfire in #3 maui_beetle 1.8 Liter Turbo 4 02-16-2010 01:10 AM
Engine misfire - P0301, P0304 and P0134 mikepn Questions, Issues, Concerns, or Problems with the New Beetle 4 02-15-2009 10:31 PM
P0300, P0302, P0303, P0304 newbluebeetle 2.0 Liter Gas 2 07-21-2008 02:10 PM
