02 NB Exhaust Diagram? - NewBeetle.org Forums
Old 09-16-2010, 01:09 AM
ebt12's Avatar
Pittsburgh, PA, USA
Car: 2002 GLS
Default 02 NB Exhaust Diagram?
Hello all,
I have been looking for months for a diagram of the exhaust system of my 02 NB and haven't been able to find one. I can feel the center has a broken hanger for even on mild bumps I can feel it hit the bottom of the car. In 2009, the garage I take the car too for its annual inspection welded the hanger back on (I didn't realize it was loose) but stated in the notes on the receipt that the hanger would need to be replaced. I want to see if this is something I can do myself. Does anyone know where I can get a diagram of the exhaust system?
Thanks!
Patrick
Old 09-16-2010, 12:00 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
If you plan on fixing this yourself I would suggest that get a Bentley Manual; it will have all the pics that you need.
My NB Family...
Old 09-16-2010, 03:28 PM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
I fail to see why a diagram would be needed. Put the car up on ramps and have a look. There should be a hanger/support in front of the cat, one behind the joint, and one back at the muffler. It should be pretty obvious where the problem is and it is an easy fix.
2000 New Beetle GLS TDI
Tags
diagram , exhaust , hanger
Electric Diagram DUENDEPUNKER 1.8 Liter Turbo 13 12-10-2010 05:55 PM
Exhaust System Diagram? ebt12 2.0 Liter Gas 0 05-27-2010 01:42 AM
2.0L A/C Diagram Shep 2.0 Liter Gas 2 05-22-2010 02:00 PM
Tr: 42 Draft Designs 3" TB Exhaust for stock Beetle Turbo S Exhaust (Chicago) r0nd3L Parts and Accessories 2 12-12-2008 11:10 PM
Caractere/Remus exhaust sounds like factory...want exhaust with some sound phinsfan99 Technical Modifications 0 08-26-2006 02:23 PM
