225/40 R18 Correct Tire Pressure? - NewBeetle.org Forums
Old 09-16-2010, 06:06 AM
eliboi's Avatar
New Beetle Noob
Philippines
Car: 2000 2.0 New Beetle
Exclamation 225/40 R18 88W Correct Tire Pressure?
Hi, I recently bought a 2000 VW New Beetle and it have Dunlop 225/40 R18 88W Le Mans LM703 (Tyres Dunlop LM703 tyre size 225/40 R18 - www.iTyre.com) on it. I cant find the max pressure on the sidewall.
What is the correct psi of my tires? Im currently at 30psi
*Already replaced air filter, engine oil, oil filter, fuel filter and still low average of 15 mpg.
Old 09-16-2010, 07:59 AM
eliboi's Avatar
New Beetle Noob
Philippines
searched the forum and saw a post using the same tire size and he's saying psi 32/32.. hope this works
Old 09-16-2010, 12:52 PM
Franco2112's Avatar
Max inflation is 51psi. For better mileage use 35 to 40 psi in all tires. My suggestion.
Similar tire. Dunlop Direzza DZ101 225/40 R18 88W
Franco
Old 09-17-2010, 03:37 AM
eliboi's Avatar
New Beetle Noob
Philippines
Franco
will i use 40 on all tires or its different in front and rear?
Old 09-17-2010, 03:49 AM
Franco2112's Avatar
Equal pressure in all, front to rear.
Franco
Old 09-17-2010, 04:42 AM
eliboi's Avatar
New Beetle Noob
Philippines
Franco
Okay thanks a lot!
Old 09-17-2010, 09:42 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
You may start to wear the tyres mostly in the centre of the tyre width with pressures that high...
Cheers
Simon
Old 09-20-2010, 08:04 AM
eliboi's Avatar
New Beetle Noob
Philippines
what pressure do you suggest sir?
Old 09-26-2010, 10:45 AM
knownaschubs's Avatar
Sandy Eggo, Cali,
well i work at discount tire, for a tire that small 40 is way too high and does wear only in the center. i'm currently running 32 so that when the tires do warm up after a little bit of driving the air pressure increases to about 35-36. and yes a couple of pounds of air does make a difference with such a small tire. at 40 psi, when your tires warm up it'll be around 45-46
Old 09-26-2010, 08:46 PM
simonsi's Avatar
Jitterbug
Car: 2000 NB 2.0
If you have no other info then I would start at 32-34psi and monitor the wear across the tyres and adjust to ensure even wear.
Old 09-29-2010, 02:28 AM
eliboi's Avatar
New Beetle Noob
Philippines
thanks for the suggestions! currently at 35 psi, and noticed a huge change in fuel consumption
alternative to tire size 225/45/17? Debugged Technical Modifications 3 08-20-2009 05:08 AM
Tire pressure funky 1.8 Liter Turbo 12 06-18-2009 04:10 AM
'04 NBC 1.8t tire pressure? killerbug New Beetle Convertible 6 06-02-2006 09:08 PM
Correct Tire Pressure? heyou Technical Modifications 8 05-29-2006 10:22 AM
What tire pressure are you using? Rich M 1.9 Liter TDI 18 05-18-2006 02:16 AM
