Rough at idle, smell of gas, lack of power and weak top speed! - NewBeetle.org Forums
Old 09-25-2010, 02:56 PM
Johnston, RI, USA
Car: 1998 New Beetle GL
Default Rough at idle, smell of gas, lack of power and weak top speed!
So, I knew my cat converter was clogged, I just had the mechanic clean it out and put a straight pipe in it for now. I will eventually replace it with a new converter, just need some more $$$.
CEL is flashing still, so guessing misfiring is still happening. What else can be causing this? I looked under the car while it was running and it looks like the whole exhaust system is shaking -- crazy!
I'm wondering if the 02 sensor is making it run rich...?
Old 09-26-2010, 06:00 PM
You can always turbo it
WI, USA
Well by removing the cat converter, you are most likely confusing the engine and allowing the exhaust to flow too quickly, which can kill power and make the car spell very gasoline like. The CEL is flashing because something is missing, the cat converter. Plus, if the cat is off, then I doubt the 02 sensor is making it run rich, plus the o2 sensor is in the exhaust lines. It could be a problem with your MAF sensor. I removed my central muffler and replaced it with straight pipe, and it does make the whole exhaust shake quite a bit. If misfiring was happening, you would totally know it. Plus i suggest using a Volkswagen CEL reader, not a standard one as they don't show the same codes. if this helps let me know
vDubOne Project
2001 2.0L NB GLS
Dyno: (stock) 122HP
Dyno: (2010) 186HP
13.695 quarter (2009)
Old 09-26-2010, 06:05 PM
Fl_bug's Avatar
Catch me riding s00ty!
Miami, FL, USA
You can get a Vw Specific code reader from the middle link in my signature
Old 09-26-2010, 08:38 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Hmmm, well if the CEL is still flashing you now have two problems, the original one and the fact that the cat is missing. the O2 sensors are in a feedback loop so DO affect how the engine runs.
Get a (preferably VCDS) code reader and get the codes...
Cheers
Simon
rough idle ericakasatch 1.8 Liter Turbo 2 05-25-2009 10:43 PM
Very Rough Idle blackonblack 2.5 Liter Gas 2 10-28-2007 02:26 PM
rough idle and loss of power in lower gears Jen's bug Questions, Issues, Concerns, or Problems with the New Beetle 2 07-17-2007 08:13 AM
Rough idle and then some alecseborp 2.0 Liter Gas 16 02-22-2007 04:18 PM
Rough Idle? SMG 2.0 Liter Gas 10 02-19-2006 03:35 PM
