Check engine light coming on then off - NewBeetle.org Forums
Old 11-04-2010, 12:22 PM
Unhappy Check engine light coming on then off
My daughters 2000 beetle has had the several lights coming off and on and now it want start. The blue coolant light comes on then changes to the red flashing coolant light then turns blue again then goes off. Then 2 days ago the check engine light came on then went and back off. Now yesterday it started and went about 100 yards and shut off and want restart. Any clues no VW experts near by so trying to get an idea on the problem before I call a tow truck to take to local garage.
Thanks,
Dad with upset 16 year old daughter
Old 11-04-2010, 12:47 PM
Supercharged98's Avatar
Fountain Inn, SC, USA
Car: 98 NB S/C'd 2.0L 5 sp
The flashin red temp light usally means low coolant, solid red is overheating. I'd check the coolant level first. And see if the coolant is pink (G-12). If it's full, the sensor might be going bad, there cheap to replace, around $10.
As for it dying and not restarting, you need to get the computer scanned first, and go from there.
"Deutsche Stahl"
Old 11-04-2010, 12:52 PM
Since you said no VW mechanics around, get this and it will help out a lot with figuring out whats going on. You can always sell if you get rid of the car.
Volkswagen New Beetle 2.0 > Tools > Scan Tools > ES#9951 V-Checker Scanner - Basic - VAGCHECKERBASIC
Old 11-04-2010, 02:29 PM
You can go to an Autozone or equivalent and they will scan the codes for free.
Old 11-06-2010, 06:20 AM
savethebluths.org's Avatar
Super smart senior member
Houston,
Thanks,
when you say it wont restart is it cranking? If it turns over but then immediately dies can you rev it and keep it alive?
Tags
check engine light , coolant lights , will not start
Brake Light, Check engine light, air bag light, but wait theres more djack19 Questions, Issues, Concerns, or Problems with the New Beetle 15 11-09-2011 10:13 AM
EPC light, Check Engine light with Codes cathlynr 2.0 Liter Gas 1 05-25-2010 07:52 PM
Check engine light/Cold light periodically bulldoggergal Questions, Issues, Concerns, or Problems with the New Beetle 8 12-17-2009 10:36 AM
2001 glx + awp engine swap = check engine light!?! NEED HELP garvitron 1.8 Liter Turbo 7 05-07-2009 12:22 PM
my beetle can't make it a year without the check engine light coming on gator Questions, Issues, Concerns, or Problems with the New Beetle 1 01-18-2008 03:47 PM
