spark plug Gap calibration - NewBeetle.org Forums
Old 11-14-2010, 04:43 AM
Default spark plug Gap calibration
Hello.
I Need Spark plug Gap Calibration,somebody know..?
thank you
Old 11-14-2010, 05:58 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Originally Posted by Geragera View Post
Hello.
thank you
Not sure what you mean but almost any autoparts stores should have a plug gapping tool...
Cheers
Simon
Old 11-14-2010, 06:39 AM
DZLBUG's Avatar
I Am Breitbart
Sauk Rapids, MN, USA
I'm guessing you are looking for the specification? I've never been under the hood of a gasser VW but it might be posted on a sticker in the engine compartment, above the radiator.
Otherwise...
Let me google that for you
Or just ask at the auto parts store, they can usually look it up for you.
2000 New Beetle GLS TDI
Old 11-15-2010, 01:21 AM
mltRegistered Member mlt is offline
St. Paul, MN, USA
Car: 2002 GLS 2.0L auto
I was recently (today) looking for this information. It turned out that it is quite hard to find specific information online. I decided to sum up what I've found. I found these links useful VWVortex.com - DIY: Replacing Spark PLug Wires on a 2.0 AEG engine. Pics inside!! , VWVortex.com - MK4 Spark Plugs Models and Specifications! , VWVortex.com - MKIV Spark Plug Database: Please add or correct if you have something new/diff. , and 2001, 2.0 Spark Plug Gap (start with local search instead of making new threads!) .
There is some discrepancy. I set mine to about .040" Google
Plugs that I removed were like .047 some of them. Which make me think they were installed uncalibrated given their somewhat good appearance.
P.S. Also I was not sure about torquing. I was afraid to break thread, and I read some people recommend when it is really tight (without ratchet) to make another 1/8 - 1/4 turn. I didn't trust my cheap torque wrench, but it did release at 120 inch pounds (10 ft lbs) when it was slightly more than 1/8 of the turn.
Tags
spark plug gap , spark plugs
What's the Spark Plug Gap? mcgarret1094 1.8 Liter Turbo 2 02-27-2010 04:21 PM
best spark plug for 2.0 bugdaddy 2.0 Liter Gas 12 10-24-2009 09:33 PM
2001, 2.0 Spark Plug Gap mmccalley 2.0 Liter Gas 3 01-31-2009 08:10 PM
2001 1.8L Plug Gap????? Peter T 1.8 Liter Turbo 11 03-04-2008 10:13 PM
What spark plug do I need? LauraLadyBug 2.0 Liter Gas 3 10-27-2006 02:23 AM
