Hi,
I have pasted the transmission warranty, last April, Now I have a DTC 17115 from my beetle. when I stop for the red light this evening, I noticed the panel shows I am still in Gear 5. I am not comfortable to Drive it now. the transmission is not switch smooth between 1, 2 and 3, I can feel the pause when the gear is changed from time to time. unfortunately, I am not qualify for the recall for the extension warranty. After scan my beetle, I have these code: 17978 17115 16955 The brake switch unit should be replaced, i would need to get a new one. Should I need to have my Transmission fixed? any suggestion? will it be clear out itself? |
The 17978 code points to an immobilizer causing the car not to start. Not sure why that code is there if you are starting the car and driving.
17115/P0731 - Gear 1: Incorrect Ratio Possible Causes * Wiring and/or connections faulty * Sensor Gear Position Indicator faulty * Gear Solenoides faulty * Mechanical failure Possible Solutions * Check wiring and connections * Check Sensor Gear Position Indicator * Check Gear Solenoides The 16955 is the break light switch. Not sure what exactly that second code means but I posted what the Ross-Tech wiki had to say on it (Ross-Tech Wiki).
I have put my brake light switch back now, will get the Lucas Oil Transmission Fix tonight. |
Hey Guys, Recently i also had a problem with my transmission the same one that everyone related here.
My car is a 2000 GLS Automatic 2.0. Sometimes when you are driving the car roughly shift from the 2nd to the 3rd and never shift to the 4th. Some other times it goes fine! I went to the dealer they said the transmission was gone, need to be replaced even knowing i had my engine light on and the codes for the wiring of the speed sensor are on, they said the only way to fix it was replacing the transmission. I take it to a transmission shop they take a ride on the car and once more the guy make me believe that my real problem was the transmission. I didn't really could believe on that, so i bought myself an auto scanner and scanned my car. I don't remember anymore the codes that came out but sensor speed and wiring speed sensor are the one related. I reset the computer 4, 5 times and i had talked to some mechanics in New jersey and i found out that the beetle have a lot of computer problems related to the transmission. Its been 4 months now that instead of paying 5.000.00 for a dealer fix my car i paid 200.00 for a scanner tool and had no more problems. If somebody else have any more troubles about this let me know !! i will make a deeply research about this and be able to answer questions. |
I got out of that post that his car was stuck in limp mode, and resetting the codes when it won't shift fixes it for him. I suppose that works if your car stays stuck in limp mode.
I took the car to the mechanic that had the last maintenance in the car, he was surprise the problem was gone. i recently did the water pump and timing belt. He told me about the transmission problem and today was gone ! |
does it work on a 2004? Turbo? I just bought mine 3 weeks ago, used, with 120,000 miles. I love her! But when I drive for about a half an hour at a constent speed, then slow down, and start to speed up again, from 2nd to 3rd gear it feels like someone has rammed into my back end.
the problem most of you have is that your transmission fluid is WAY past its useful life....
VW claims it is "lifetime" fluid...this is a farce....the fluid breaks down like any other oil and needs to be replaced....that should REALLY help with shifting problems...AND extend the life of your tranny (as opposed to damaging it due to crappy fluid) |
Sent from my DROID2
| Tags |
| transmission |
| RUH ROH! Ran into a problem with the oil filler on my transmission | savethebluths.org | 2.0 Liter Gas | 2 | 07-18-2010 04:15 PM |
| transmission problem | whitelighting | 2.0 Liter Gas | 1 | 05-27-2009 12:07 PM |
| Transmission Problem? | sjdean101 | Transmission Talk | 0 | 02-14-2009 03:24 PM |
| Transmission problem..2001 2.0 | Buggie01 | Transmission Talk | 0 | 08-18-2008 03:55 PM |
| Transmission Problem | who_me285 | 1.8 Liter Turbo | 18 | 06-12-2007 02:02 AM |
