Thirsty buggy - WHERES ALL THE COOLANT? - NewBeetle.org Forums
Old 01-09-2011, 09:14 PM
Mr.Pearl's Avatar
MORAcamaro
NYC, NY, USA
Car: 2001 New Beetle GLS Reflex Silver
Exclamation Thirsty buggy - WHERES ALL THE COOLANT?
Hey guys
When I start up my beetle, a blue coolant symbol appears. Then shortly after (about 15 mins of driving) a flashing red coolant sign comes on.
Sometimes it just starts with the flashing red coolant symbol.
I have refilled the coolant tank 3 times in 1 week. I have checked and do not see a leak. But also note, I am not a professional.
Where is all my coolant going? I know I should not be using the standard green stuff and have yet to get the pink g12.
ne ideas?
thnx~!
* note there has been an unknown CEL for at least 4 months now, even after a diagnostic.
Old 01-09-2011, 09:17 PM
If there is a CEL on, there is a code. You need to get that code read. Could help point you in the right direction.
Has the water pump/timing belt job been done on the car? How many miles on the car? Are you adding green coolant to the pink? If so...that's a huge no-no. Hopefully you are just adding distilled water.
Old 01-09-2011, 09:22 PM
MyOtherRidesAVette's Avatar
Mr. Pearl! Hi! Weren't sure you or the Miss would be back. I'm guessing you just have a real thristy Kafer! (lmao) You may simply just not have it full! Although, where did it go to begin with! Hope you're not blowing it out your exhaust because of a gasket problem.
I want to believe there is a valve between the expansion tank and the radiator. Try filling the radiator AND then the expansion tank. You seem to be reading the indicator light properly. Blue simply an indication of engine temperature, red low coolant. Get that ucky green **** out of there, Buddy. G12, period. And it wilol need a good flushing.
Ditto getting the code read with the proper diagnostic equipment, sounds like an auto parts store read!
MORAV
In der Automobil-Scheune
Old 01-09-2011, 09:33 PM
2004NBTURBOS's Avatar
Peace Love & T.o.D.
Ocean View, DE, USA
Car: 1st 2000 GLX now 03.5 TS
Originally Posted by MyOtherRidesAVette View Post
Try filling the radiator AND then the expansion tank.MORAV
There is no radiator cap. The expansion tank is the only way to add fluid to the system. At least in my 2000GLX an 2003 TS.
Old 01-09-2011, 10:11 PM
JP's Avatar
JPRegistered Member JP is offline
Cortlandt Manor, NY, USA
Car: 2001 VW Beetle GL 2.slow
had this same issue a couple of month's ago, turned out to be a leaking lower radiator hose it dripped so slow it won't leave mark's on the floor finally found it when it snowed and i saw a stain on the white snow, but i just noticed on your post you filled it up 3-time's in a week.
Old 01-09-2011, 10:16 PM
Yes, I got that info in another post, but read a comment about there being something else that worked like a cap. Guess I need to go look at one of mine!
Old 01-09-2011, 10:36 PM
Mr.Pearl's Avatar
MORAcamaro
NYC, NY, USA
No water pump/timing belt job done since we got her in May 2010. she has 53k miles. Unfortunately its been just the green stuff (coolant)...where can I get g12? dealer only?
Most importantly, we have taken the car to 2 places to get the CEL read and no codes show up.
Old 01-09-2011, 10:52 PM
One of the corner auto parts chains carries it. Try a search for coolant in the threads, last 4 weeks. use "coolant", three numbers/letters won't search I just found out. Or www.ecstuning.com You need G12, not G11
What kind of equip are they reading it with. Was it a dealer or a VW Specialty Shop. For some codes, I understand, it takes a Vag-Com.
MORAV
Old 01-09-2011, 11:05 PM
There is actually a thread on here for Orgers who have Vag-Coms and may be in your area or close, willing to help. You still haven't put any location in your statistics that tells us where you are.
MORAV
Old 01-09-2011, 11:14 PM
Mr.Pearl's Avatar
MORAcamaro
NYC, NY, USA
yea - sorry about that, we're in NYC. I haven't had access to my bio/info but i asked to mods to help me out idk.
that would be great for 2 reasons
1. to meet an nb.org-er
2. well....to fix the prob LOL
ne new yorkers here?
Old 01-09-2011, 11:22 PM
There's a bunch just across the bridge or thru the tunnel (lol), and a couple out on L.I.
Anyway, did you click on the User CP, on the left side of the lower purple bar at the top of the screen? It should take you to a list of control panel items down the left side. From there you can click into different things and set up things the way you want them. If you need help and are not comfortable doing that on here, feel free to p/m me. Simply click on my user id name in the top left corner of my post, and select "send private message".
Always glad to help a newbie with anything!
MORAV
Old 01-09-2011, 11:27 PM
Mr.Pearl's Avatar
MORAcamaro
NYC, NY, USA
haha - yea i appreciate the help. It's some technical glich tho. newbie for sure, but even tho i keep editing, the info has me saved as some1 else that's been a member for a few years now lol (Fiona Pearl...idk who that is)
Mistaken identity
Old 01-10-2011, 01:14 AM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
The reservoir cap that is pressurized as well as the regular radiator cap. That's from when Jason yelled @ me a couple of days back
I thought I read somewhere around the org that using anything but G12 would throw a cel? Or maybe I just made that up.
—Ambrose Redmoon
Old 01-10-2011, 01:37 AM
Mr.Pearl's Avatar
MORAcamaro
NYC, NY, USA
Originally Posted by J.Arce View Post
...I thought I read somewhere around the org that using anything but G12 would throw a cel? Or maybe I just made that up...
that would be amazing, but believable ... tricky German engineering.
Can I do a flush myself? Or should I leave that to a pro? I am going to order a gallon online ($22 yea!)
Old 01-10-2011, 02:03 AM
Mistaken identity
Yeah, I remember now. You never got that handled? I'll find the user id for an admin. I thought Dnyed was going to handle it.
Your right, I click into your page and get Fiona Pearl. The only Fiona I know is Michael Westen's side kick on Burn Notice, and WOW, that'sa Fiona!
MORAV
Old 01-10-2011, 02:34 AM
batikbluesmommy's Avatar
luvmybatikbluegrl
wirtz, VA, USA
Car: 2000 2.0L auto batik blue
Hey guys
ne ideas?
thnx~!
Dont use the regular coolant for your bug, its just burns up, either use vw coolant or there this new stuff that is consetrated and mixes with any color and is for any make or model and it does work cus im using it in my beetle, but if you do dont put vw coolant on top of the universal stuff. have your water pump checked, it could be comeing out while driving, and also unlike most cars, beetles have a way to work the fluid into the system unlike a radiator cap, it takes ours to get it back in, your water pump is made with a plastic impellor also, if you havent replaced it with a metal one they brake easily once it breaks you loose all your coolant quick, i have an extra water pump if you want it, it is plastic but not broke, i replaced mine anyways..good luck
oh sorry for spelling
Old 01-10-2011, 03:23 AM
JP's Avatar
I'm in Westchester county N.Y. and i work in Da Bronx, NAPA auto parts has G12, for like 16.00 a liter on the shelf you just gotta mix it as it is concentrate, also if your close to Yonkers NY Go to Total automotive warehouse on lake street if you need more info PM me
kellyyysayss's Avatar
Mount Holly, NJ, USA
Car: 2000 Beetle, 1964 Comet Caliente, 1966 Mustang
Do a radiator flush yourself. It will take time. I have the how-to if you want a copy.
You should mix your coolant (G12) 70% g12 30% distilled water after the flush.
I highly rec. a water pump/tb change. It sounds like a hose leak or the pump is on it's way out. I didn't see the year of your car but it probably needs new radiator hoses (upper and lower). Another easy DIY.
If you need help with any other issues I'm about an hour away.
Old 01-10-2011, 07:44 PM
Mr.Pearl's Avatar
MORAcamaro
NYC, NY, USA
WOA! Thanks guys.... guess we've got a lot of work cut out for us
kellyyysayss, that's really nice of you- does that need to be e-mailed? idk or pm lol
(we are tinting this weekend, so maybe it will be an all bug day that day once we get the g12)
Old 01-10-2011, 08:43 PM
I will PM it to you when I am home.
If you do decide to do the flush, change the hoses....so you don't have to empty the system twice. Use the flexiclamps if they're still on you're bug.
Tags
blue , coolant , g12 , red
Punch Buggy peanutsmom The New Beetle Experience 3 06-21-2010 02:37 PM
Funny Buggy buckbeetle Miscellaneous Hoo-Ha 2 02-12-2010 05:21 PM
Northwest Gal w/ Buggy NEW NEW here :) Bbyblubug New Member Forum 11 06-29-2008 12:34 AM
wheres coolent temp sensor brad66247 2.0 Liter Gas 0 09-27-2007 01:59 AM
wheres that thread describing what the spoiler light means? ninsei 1.8 Liter Turbo 16 12-20-2005 05:00 PM
