Coolant flush? - Page 2 - NewBeetle.org Forums
  #21 (permalink)
Old 08-30-2011, 12:13 PM
Car: 1998 New Beetle
Here's a question. Is refilling the coolant done by pouring it into the spherical recovery tank? Or is this done my adding it directly to the radiator itself. I ask because I cant seem to locate the radiator cap, and because the recovery tank cap seems beefier and more purposeful than in other cars. Sorry if this is a dumb question. I just don't want to remove the plastic shroud on top of the radiator looking for the radiator cap if there really isn't one. Thanks for any help
P.S. The car is a 1998 Beetle w/2.0L engine
  #22 (permalink)
Old 08-30-2011, 12:35 PM
You add into the coolant reservoir. Should just be a blue cap on that round reservoir on the passenger side of the car.
  #23 (permalink)
Old 08-30-2011, 01:02 PM
Thanks for the fast reply! I'm glad to know the coolant will be able to get down into the radiator from the recovery tank
  #24 (permalink)
Old 08-30-2011, 01:40 PM
MyOtherRidesAVette's Avatar
Just be sure you are using G12 coolant. Ideally you want a 50/50 mix in the system. And just FYI, there is no radiator cap. If you want to learn a little more about the coolant system, or for anyone who came here looking for the proper way to drain and fill the system, go here -
Beetle overheating
M.
  #25 (permalink)
Old 09-13-2011, 08:11 PM
Default FYI 2006 2.5 New Beetle 9.5L/10 qt
Just fyi. I could not find it in my OEM manual. Had to go to the mountain and ask the local VW dealer service dept. Ha he didn't know either. Their method is flush and fill with one gallon. Pushed it and he finally found it, 9.5L/10 qt. Which for my model makes a flush + 1 gallon 60/40. Manual says 50/50 or 60/40 coolant/H20.
  #26 (permalink)
Old 09-13-2011, 08:47 PM
If my math is correct, your statement 60/40 (coolant/water), is incorrect for 4 qts coolant / 6 qts water.
M.
In der Automobil-Scheune
  #27 (permalink)
Old 09-14-2011, 11:22 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Originally Posted by kwalla73 View Post
Anyone have an issue with the coolant drain valve leaking even after fully closed after a coolant flush and refill? I did. I have a '99 Beetle w/ a 2.0 engine.
Never have bit it is quite possible to get some debris under the washer seal and it would leak. Try back-flushing, connect a 1/2in garden hose to the drain with the system drained, the coolant tank open and the drain tap open then use some mains water pressure to try and dislodge any debris, disconnect hose and allow it to drain then see if she seals up.
Also check the drain tap is fully closed.
Cheers
Simon
  #28 (permalink)
Old 09-24-2011, 09:05 PM
Calgary, Alberta, Canada
Car: 00 Beetle GLS
Hey all, What is the benefit of the G12 coolant over the regular green stuff? And is the green stuff bad for Beetles?
Thnx!
  #29 (permalink)
Old 09-25-2011, 12:52 AM
gorj's Avatar
00678_PR_USA,
Car: 99 beetle 2.0 ,..90 mazda b2200
mykul2.0,
a good post / debate on the issue is here:--> G12 Coolant vs the Green STuff ??
  #30 (permalink)
Old 09-25-2011, 02:00 AM
mltRegistered Member mlt is offline
St. Paul, MN, USA
Car: 2002 GLS 2.0L auto
Question How do you drain coolant from cylinder block?
How to drain coolant from cylinder block without making a huge mess? Bentley says to disconnect lower hose at oil cooler to drain cylinder block after coolant draining from the valve nearby radiator is done.
It is really tight in there even after removing SAI pump I drained only 2.75L so far from under the radiator.
  #31 (permalink)
Old 09-29-2011, 10:27 AM
What if you don't know what coolant is currently in your car?
I just bought a 2001 NB and the used car dealer put in a new water pump and timing belt. I doubt he took the time and cost to get the VW G11 or G12 coolant. I thought about asking him what coolant he used but I wouldn't fully believe him anyway so I dodn't bother to ask.
Is there any test to see what you have?
  #32 (permalink)
Old 09-29-2011, 12:39 PM
What color is the fluid in the reservoir? I'd also ask.
  #33 (permalink)
Old 09-29-2011, 12:41 PM
VDubYah's Avatar
Orlando, FL,
Vw coolent should be pink G12 or Purple G12+ if its orange or green its the wrong stuff.
  #34 (permalink)
Old 10-02-2011, 07:00 AM
St. Paul, MN, USA
I just want to confirm I read somewhere that it is okay to mix G12 and G12+. Is it? The problem is that I failed to drain coolant completely but the one that came with a kit is G12+ purple while I have probably G12 as it is reddish.
  #35 (permalink)
Old 10-02-2011, 11:18 AM
I wasn't aware of a G12+ (maybe the pre-mix? or a hybrid G12) but I had read of a G13 (purple) in the Bentley, and it indicated they could be mixed (the G12 and the G13).
M.
engine coolant flush? jbremount 1.8 Liter Turbo 19 10-20-2010 04:02 AM
How to flush the coolant? thatpastorguy Technical Modifications 6 10-21-2008 04:32 AM
How should I flush my coolant and refill??? Please HELP! BooBah 1.8 Liter Turbo 5 09-01-2007 04:30 AM
Coolant flush fohveh Questions, Issues, Concerns, or Problems with the New Beetle 4 11-16-2006 08:57 PM
Coolant flush ms03bug 2.0 Liter Gas 8 01-03-2006 09:30 PM
