Quick motor mount question -- need help! - NewBeetle.org Forums
Old 02-14-2011, 09:36 PM
Fallbrook, CA,
Default Quick motor mount question -- need help!
Hi folks,
I'm trying to change the timing belt on a '03 2.0 with the AVH motor.
It looks like I should only need to remove the piece of the motor mount that attaches to the chassis and NOT have to mess with the inboard mount portion that's fastened to the engine.
Is that correct?
I appreciate the help as I can't find any DIY info on this engine type.
Old 02-14-2011, 09:44 PM
IL, USA
Car: Mercedes AMG C55
Can't say for sure on an AVH, but on the AEG you do need to remove the motor mounted piece. It really is no big deal at all, on a AEG it's only three bolts. The only trick is understanding that you have to raise and lower the engine a fair bit to expose the bolts. Also raising and lowering will help get the mount removed. By doing this I got a torque wrench on all three when I was putting it back together.
Old 02-14-2011, 09:51 PM
Fallbrook, CA,
Thanks. I have the DIY write-up on the AEG motor and they don't appear to be similar, hence my question.
Anybody else have some insight? If not I guess I'll have to button things up and drive over to a shop and ask.
Old 02-14-2011, 09:59 PM
IL, USA
Sorry about that, I just read on the VW Vortex DIY where some of the guys had the worst time removing that mount and it wasn't clear to raise and lower the motor on a jack to ease the job.
Old 02-14-2011, 10:22 PM
IL, USA
I looked up the support bracket on a VW parts site and they show the same part for 1998-2005. Can you take a picture of it?
Old 02-14-2011, 10:38 PM
Fallbrook, CA,
The top pic is the one I'm working on, the lower is from the Vortex DIY for the AEG motor. VWVortex.com - DIY: Timing Belt And Coolant Pump Replacement on 2.0 AEG! Pics Inside!
I could be smoking something but there seemed to be discrepancies from one to the other.
Old 02-14-2011, 10:44 PM
Fallbrook, CA,
And here's a longer shot, too.
Old 02-14-2011, 11:26 PM
Fallbrook, CA,
Phil, can I get the link for the parts info you mentioned?
thanks
Gary
Old 02-15-2011, 12:11 AM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
AFAIK all 2.0 gas NB engines use the same block and engine mounts, and yes the inner section bridges over the TB so needs to be removed to change the TB or WP.
Your pics show the same mount I have on my 2000 as far as I can tell.
Cheers
Simon
Old 02-15-2011, 11:27 AM
IL, USA
Thanks for the pic, yup it's the same, what's throwing you is the power steering fluid reservoir in the DIY pics. My 2000 looks exactly like the pics of your car. It also uses the same kit for the water pump/timing belt job.
Here is a link to the side support part
Volkswagen Parts, Accessories & Genuine VW OEM Parts @ vwpartsoem.com
Old 02-15-2011, 01:44 PM
Fallbrook, CA,
I'll be darn. Well, glad I asked and thanks for the help!
Now I guess I have no other excuses ... oh well.
Old 02-15-2011, 01:56 PM
IL, USA
One other thing I came across. In the pic of your car you can see the two rubber fuel hoes side by side (wrapped half way with a rubber cover) that go to the plastic fuel rail where the fuel pressure regulator is. For the life of me I couldn't get the quick disconnect fittings to release. I could get one but not all, I ended up removing the two lines at the regulator fittings. They came off pretty easy, but being a plastic hose barb made be a bit nervous.
Old 02-15-2011, 07:35 PM
simonsi's Avatar
Jitterbug
Car: 2000 NB 2.0
I work around them, no need to disconnect.
Old 09-26-2011, 03:21 AM
mltRegistered Member mlt is offline
St. Paul, MN, USA
Car: 2002 GLS 2.0L auto
Question How to get a good access to the engine mount?
How do you guys make space for TB job? I'm about to do it on 2002 AZG 2.0. I feel like I can get an access to engine mount bolts by just moving coolant expansion tank around a bit but I have no clue how to remove it from that tiny spot to make more room Should windshield fluid tank come off? It seems like too much work. Also What is the method to disconnect hoses shown with green arrows? Do I remove one-time use clamp or is there a way to disconnect plastic parts?
Old 09-26-2011, 03:38 AM
VDubYah's Avatar
Orlando, FL,
When you remove the motor mount and the timing belt covers they is a lot of room to work. Pulling the passenger wheel and the passenger side plastic splash guard thing if it is still there gives more room and you can see everything you need to. You will need new motor mount bolts are they are single use. No nee to remove the coolent resvior or washer tank.
Old 09-26-2011, 04:07 AM
St. Paul, MN, USA
Wheel and liner are already off.
I was confused by DIY guides for other VW vehicles on vwvortex. Though Bentley also doesn't mention coolant tank removal. But out of curiosity shall windshield washer fluid tank come off to remove coolant tank?
I just wonder about bolts. To play safe I ordered virtually all bolts I'm about to remove. The guy at the dealership was surprised as many of those (including some of 6 bolts mentioned at Bentley as "always replace") haven't ever been in their system so he had to explicitly add an order for them or something. When I was picking them up, another guy was also surprised as he said those I ordered were not stretch bolts as they were not greenish. The ones I have in the bracket are indeed of greenish tint. I doubled checked all p/n with ETKA. ETKA says only mount to body (N 105 167 02) is self-locking. Service guy at the dealership said they replace sometimes mount to engine bracket bolts (N 102 095 05 ?) only if the thread really looks bad. Also it looks like it would be hard to remove another bolt from mount side support with coolant tank around.
And what about fuel hoses?
Tags
timing belt
Broken Motor Mount AGAIN Papa Gino 2.0 Liter Gas 2 04-26-2009 11:11 PM
FS/FT: Stock lower dogbone motor mount j_oly1999 Parts and Accessories 2 09-10-2008 10:30 AM
how to change motor mount guide? Carphunter Questions, Issues, Concerns, or Problems with the New Beetle 7 06-12-2008 06:48 PM
motor mount issues I think???? help veedub71 1.8 Liter Turbo 1 05-05-2006 09:11 PM
