Oil on spark plugs - NewBeetle.org Forums
Old 03-27-2011, 04:12 PM
Default Oil on spark plugs
Does anyone know what causes oil to get on the spark plugs?
Old 03-27-2011, 04:39 PM
Tico4Life's Avatar
treiber gefunden
UNION, NJ, USA
Car, engine, year? My guess would be worn piston rings and/or valve seals or guidelines.
—Ambrose Redmoon
Old 03-27-2011, 07:15 PM
1998 beetle 2.0 gas engine
Old 03-27-2011, 07:37 PM
Garage
How many miles on the car?
The Baby Brother: Günther, Stage 2 Unitronic, 20th Anniversary Edition GTI
Old 03-27-2011, 07:49 PM
Just under 200,000
Old 03-27-2011, 11:50 PM
cep's Avatar
Who is John Galt?
Grubsoil, KS,
Originally Posted by dannull View Post
Just under 200,000
Wear.
It's 13 years old and 200K. Although engines usually last longer than that these days, that's still quite a few miles and under what conditions? 200K with a K&N filter, it would not surprise me at all that the rings, pistons, and bores would be shot.
'02 & '05 Acura RSX
Dodge Cummins, Ford Ranger
M151 Ford
Old 03-28-2011, 02:36 AM
Pierce County, WA, USA
Car: 2000 GL
wear & tear.
Most common issues of this symptom are:
Piston rings going bad, badly worn cylinder walls, valve stem guides, or badly worn valve stem seals, also if the PCV system is bad. clogged or inoperative. This could cause pressure to build up in the engine causing the leak as well.
Old 10-05-2011, 03:58 PM
IndyTom's Avatar
Indianapolis, IN, USA
Car: 2012 Tornado Red VW Beetle Tsi
Originally Posted by Pseudotropheus View Post
wear & tear.
I have a similar issue with my 2000 1.8 160k mile Beetle. I just changed the spark plugs and the chambers where the coils are sitting in were totally soaked with oil. The thing is that the spark plug tips were perfect and no oil fouling on the electrodes or ceramic tip at all. Also the car does not burn any oil between changes. So where could this oil be coming from? How do I check the PVC system? I am sure it is pretty old and needs replacing but I don't know where to look and what to replace. Overall the car runs GREAT and there is no hesitation or lack of power so I think my compression is up to par. Thank for any help and or suggestions.
Tom in Indy
Old 10-05-2011, 04:53 PM
D2Beetle's Avatar
No NB Yellow Trifecta :(
Springfield, TN, USA
Car: Sliver '00 GLX Turbo / Yellow '14 Fiat 500L / Black '15 TSI Turbo
Do a compression check. My '98 is 7,000 miles short of 300,000 and runs great. I might be a faulty head gasket.
My NB Family...
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Spark Plugs SIX SPEED 1.8 Liter Turbo 28 01-10-2013 05:59 PM
Spark Plugs on a 2.0L digifant_gli 2.0 Liter Gas 14 05-08-2012 08:20 PM
E3 Spark Plugs Dakota Technical Modifications 6 10-04-2011 03:50 PM
Getting to spark plugs dermusikman 2.0 Liter Gas 12 12-26-2009 12:23 AM
70+ hp from spark plugs? Fowvay Questions, Issues, Concerns, or Problems with the New Beetle 17 09-21-2006 03:25 AM
