P0442 Code - NewBeetle.org Forums
Old 04-05-2011, 02:54 PM
Default P0442 Code
P0442 code pulled twice in the last couple of months. Tightened the gas cap and cleared the code both times but it reoccurs. The vehicle is running fine. Anything in particular I should be looking for?
Old 04-05-2011, 04:03 PM
MyOtherRidesAVette's Avatar
Question
While this has gone unanswered, I'm assuming this is what lead to your other post, doubtful the other way around. There has to be a sensor of some type, not sure where it is located, or what it actually reads. Know that it trips a warning light in your cluster, didn't know it thru a code (if in fact that is what is triggering the code). Possibly the sensor gone bad or a wire loose. Hopefully someone can come on and help out.
MORAV
In der Automobil-Scheune
Old 04-05-2011, 04:41 PM
The other post is related to the lid not closing, not the actual gas cap. Do you think that if the lid does not close it could cause pressure issues and trip the code? Haven't thought of that yet.
Old 04-05-2011, 05:00 PM
Question
No, I thought you were having issues with the cap, but now that you mention it, maybe the sensor is for the flap, and not the cap. What is the description, verbatim, of the code?
M.
Old 04-05-2011, 05:04 PM
Garage
MORAV, this is for you...from the Ross-Tech Wiki:
16826/P0442/001090 - EVAP Emission Control Sys: Small Leak
Possible Symptoms
* Malfunction Indicator Light (MIL) active
Possible Causes
* Evaporative Emission (EVAP) System leaking
Possible Solutions
* Check Evaporative Emission (EVAP) System Sealing
o Check Fuel Cap
Seems to only point to the cap. I haven't had this problem, but I know I've seen people post about it on here before so hopefully someone will chime in soon.
Old 04-05-2011, 05:16 PM
Thumbs up
Possible Symptoms
Possible Causes
Possible Solutions
o Check Fuel Cap
Thank you, Darlin! Just what I wanted. OPer states the cap is on tight, so if it's cap related, perhaps the gasket on the cap is bad or missing. If not, then I'm seeing a bad or malfunctioning sensor (wiring issue maybe), or leak in the system (the EVAP System can have a leak other than at the cap), as noted in the Wiki.
M.
Old 04-05-2011, 06:15 PM
I'm gonna pull the tail light out and check the evap canister and hoses for cracks. I'll probably buy a new gas cap as well since they're cheap.
May take me a few days to check this out since I buggered my hand up. Will post findings. Please keep suggestions coming!
Old 04-05-2011, 06:28 PM
Thumbs up
Be sure to come back here an post up with what you find! Helps others in the future with the same symtoms!
M.
Old 04-06-2011, 01:21 AM
I removed the gas cap housing and the right rear tail light for a better view. All hoses appear in tact, in very good condition, with no signs of cracking.
I'm going to try replacing the gas cap and the housing(door won't close due to breakage this winter).
Old 04-09-2011, 09:05 PM
Filled up the other night and removed the gas cap this morning. Pressure left the tank. I highly doubt at this point that the gas cap is the cause since it was able to hold that much vapor back. I've adjusted the fuel door as well. Any other suggestions at this point?
Old 04-09-2011, 09:36 PM
Question
As I mentioned somewhere, there has to be a sensor. Problem is I don't know what exactly it senses. Gonna look for that on the parts diagram while I'm looking at the release.
M.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
code help mrsbeazley 2.0 Liter Gas 1 07-26-2010 05:01 PM
p0442 help me jdubvdub 1.8 Liter Turbo 8 03-10-2010 03:31 PM
turbo intake code abe, engine code aeg huck731 2.0 Liter Gas 8 11-03-2009 11:43 PM
ABS Code ??? jazzman_q 2.0 Liter Gas 1 05-31-2006 04:43 PM
cel code 411 racer12306 2.0 Liter Gas 5 01-03-2006 03:53 PM
