How to change right rear brake caliper? - NewBeetle.org Forums
Old 05-04-2011, 05:44 PM
Milwaukee, WI, USA
Car: 1999 2.0L 5 speed 133K miles
Default How to change right rear brake caliper?
I have a 99 VW beetle 2.0 that needs the passenger side rear brake caliper changed. I already picked up the new caliper and brake fluid. I've changed brage caipers on other cars in the past but I wanted to know if there are some Beetle specific things I should know.
1) Where do I pour in new brake fluid? I couldn't find the master cyliner?
2) Do I need to bleed all brake lines when the job is done or is it ok just to bleed the line going to the new caliper?
Any tips would be appreciated.
Old 05-04-2011, 06:00 PM
Toad's Avatar
big poster turned lurker.
Cumming, GA, USA
Car: 03 Turbo S, 99 Cabrio, two 87 Audi 5000's
The master cylinder is reachable after you take the airbox out. Like all car's it's mounted on the firewall on the other side of the brake pedal. That's just how the beetle is built, with the firewall way in back of the engine bay.
As a general rule, you should flush you brake fluid completely every 2-3 years. So i would recommended flushing the whole system if you have the time.
If I could begin to be half of what you think of me. I could do about anything....
Old 05-04-2011, 07:30 PM
i recently replaced my right and left rear calipers....they are perfectly strtaightforward...they have a bleeder valve you crack to bleed...really nothing special at all....you do need a special tool to retract the piston....it will rotate the piston as it is pressed...you wont bhe able to retract the piston without it.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Rear Brake Caliper Piston and E-Brake Cable Won't Budge themerk Questions, Issues, Concerns, or Problems with the New Beetle 7 12-13-2010 09:25 PM
Cannot reverse after changing rear brake pads and caliper hello_computers 1.8 Liter Turbo 0 08-07-2010 01:48 AM
Rear Brake Caliper REMOVAL Stevgtguy 2.0 Liter Gas 4 04-15-2007 02:04 PM
Brake Caliper Painting? 13Beetlejuice13 Paint and Body 12 10-24-2006 05:58 PM
G2 Brake Caliper Paint Kit iScott Paint and Body 8 06-30-2006 01:15 PM
