Oil Leak after Oil Change - NewBeetle.org Forums
Old 05-12-2011, 06:04 PM
Christina
Los Angeles, CA, USA
Car: VW Beetle 2004 2.0L
Default Oil Leak after Oil Change
Hi,
I just got an oil change on Sunday. I noticed oil was leaking yesterday afternoon. Could it be the plug was not properly tightened? My car had not been leaking any oil until after I had it changed.
Thanks!
Old 05-12-2011, 06:27 PM
SenileDavid's Avatar
Denton, TX,
Car: 2004 Beetle GLS Orange 'Vert
Originally Posted by chrysp View Post
Hi,
Thanks!
I don't want to bring bad news... but it could also very well be from over-tightening that strips the oil pan (just had mine replaced)
Old 05-12-2011, 06:48 PM
Christina
Hmm...well I'm going to go have it checked today. Also, do you happen to know what king of engine oil is best for 2004 beetle? I believe I use Castrol 5w-40.
Old 05-12-2011, 07:08 PM
Denton, TX,
About your oil leak, I would take it back to who changed your oil and demand for them to check the drain plug with you present to verify. If they stripped it, I'd make them pay for an oil pan.
In regards to engine oil this subject has been touched many times the most recent thread What OIL to use
Castrol conventional 5w-40 is a good choice for non-turbos.
Old 05-12-2011, 08:37 PM
Garage
I run 5w40 Castrol Syntec in my 2.0 and have for over 5 years. I'd say you're good with that choice.
Old 05-12-2011, 10:35 PM
Mundelein, IL,
Car: 2002 GLS 2.0
A worn out drain plug crush washer will definetly cause a leak at the oil pan drain plug.
Did they replace it?
Old 05-13-2011, 02:53 AM
4SEVEN3's Avatar
Blue ones are faster!
Greensboro, NC, USA
Car: 2004 GL Lagoon Blue
+1 that will do it every time. You can get away with reusing it once in a pinch, but no more than that.
4SEVEN3
Old 05-13-2011, 05:46 PM
mltRegistered Member mlt is offline
St. Paul, MN, USA
Car: 2002 GLS 2.0L auto
Yep! I had this happened too. Here is another thread: Oil Leak Help
Old 05-14-2011, 03:42 AM
Pierce County, WA, USA
Car: 2000 GL
Someone could have double gasketed it on accident. Happens all the time.
Old 05-18-2011, 10:38 PM
Christina
Turns out there were a couple of "washers" placed to tighten it and they showed me. They are telling me that I it's best to replace the oil pan completely because it keeps leaking oil. Less now after I had it tighten, but still leaking nonetheless. =(
Old 05-18-2011, 11:32 PM
Denton, TX,
Most likely they over tightened it
Old 05-19-2011, 01:16 AM
Christina
I have been using Castrol GTX 5w-30 (non synthetic). I don't know what type of oil the owner before me was using.
Old 05-19-2011, 03:26 AM
Car: 2000 GL
Dont listen to the snake juice. As long as there is oil in your crankcase, you are good to go.
There are cars reaching 300-400K in miles running conventional oil. Your oil is fine. Keep using Castrol, and remember conventional oil is real oil. Synthetic is created in a lab.
Old 05-19-2011, 04:44 AM
Denton, TX,
Originally Posted by Pseudotropheus View Post
.... Synthetic is created in a lab.
Perhaps that's why they call it SYNTHETIC? I'm just guessing here...
Old 05-19-2011, 04:58 AM
MyOtherRidesAVette's Avatar
Unhappy
Oh, here we go , again!
I have decided to succumb to those so much more knowledgeable than myself about oil and engine lubrication and delete my posts in this regard. I will learn.
Old 05-19-2011, 06:41 AM
Denton, TX,
You're alot nicer than I...
Old 05-19-2011, 01:08 PM
Ours had a dribble from a damaged pan at the plug which had been JB-welded by a previous owner. I changed the pan to a steel/alum one similar to: VW Mk4 1.8T Steel/Aluminum Oil Pan for ~$100. Not a big job and there is a thread to show you how if you need. Not a drop on the drive since then. Good luck.
Old 05-19-2011, 02:35 PM
Smile
No, just getting smarter as my time and experience here on the Org increases.
Old 05-19-2011, 02:38 PM
Car: 2000 GL
If her using conventional oil is "supposedly" bad. Then I would ask for evidence showing this.
Lay it all on the table. Show me conventional oil is no good. Oh wait, I guess we wont be going into that because there isn't any proof that auto shops who use conventional have more issues or come backs. There also is no manufacturer that states in their manual that conventional oil will destroy your car. Most shops carry a weight of oil that is good to use for which the climate they live in.
Therefore "as long as there is oil in your crankcase, your car will be fine".
Old 05-19-2011, 02:56 PM
Garage
Have you seen the sludging that occurs in 1.8T engines that use conventional?
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
Insurance
Include me on the map?
Log-in
Human Verification
You may post new threads
You may post replies
Help fixing coolant leak (with pictures of leak)- Xpost from General Questions rmi 2.0 Liter Gas 24 10-05-2015 01:53 AM
Oil leak after 1rst oil change. shafrs3 Questions, Issues, Concerns, or Problems with the New Beetle 13 04-09-2011 10:04 PM
Help fixing coolant leak (with pictures of leak) rmi Questions, Issues, Concerns, or Problems with the New Beetle 0 08-06-2010 10:44 PM
so if i want to change my exhaust tips I need to change my muffler? MichelleRoze Styling Modifications 15 07-02-2008 06:42 PM
Possible oil leak? heatherm Questions, Issues, Concerns, or Problems with the New Beetle 1 12-21-2007 09:41 AM
