It could be a few things but most likely its your throttle body, specifically the motor that controls it (some call it the IAC but its different)
It could be bad which would require a replacement but most likely you just need a throttle body alignment, easy to do with a VAG. I would also recommend taking the TB off and giving it a good cleaning with some TB cleaner. |
Thanks for the input. I hadn't thought of cleaning the TB and after doing some research on here, it seems fairly straightforward.
I do not have access to a VAG, could I just reset it but unhooking the battery or doing the method that involves putting the key "on"/but not started for a few minutes? Got the battery checked again yesterday, two different shops, both said my battery is bad/replace immediately. |
![]() You can buy one of those $10 ones off ebay and use the really old free rosstech software it comes with and do it just fine. |
| Tags |
| '99 , a/c , manual , stalling |
| 2003 GLX 1.8T, goes into neutral instead of 2nd gear. PLEASE HELP | missstarsineyes | Transmission Talk | 1 | 06-02-2010 10:50 PM |
| vibration around 1600-1800 in neutral... | Dwight | 1.9 Liter TDI | 0 | 11-21-2009 12:32 AM |
| NB'2001 engine shifted after hitting a pothole | myanna555 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 07-20-2009 11:18 PM |
| Shifting to neutral at the light .... who does it and why ? | neko | Transmission Talk | 2 | 10-19-2007 05:07 AM |
