Testing and replacing the cam position sensor - NewBeetle.org Forums
Old 07-04-2011, 02:56 PM
Red face Testing and replacing the cam position sensor
My 2001 2.0 is throwing an error code P0343 which is the cam position sensor. One of the threads says to test the voltage on the CPS connector (wires 1 and 3). It checks out. The thread also says to crank the engine by hand and test the voltage on wire 2. To do that, I need to cut into the wire and test it. I do not have a wiring diagram and cannot figure out which is wire 2 in the harness.
Can someone tell me what the colors are for wire 2 on the CPS?
Also, to replace the CPS, to me it is no 10 minute job. The motor mount support must be removed to be able to get the timing belt cover off. Is that correct.
Thanks in advance. Obie
Old 07-04-2011, 04:35 PM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
If it is a 3 pin connector; it is the one in the middle.
My NB Family...
Old 07-04-2011, 04:43 PM
I know it is the number 2 pin in the middle. But the way the electrical connector is made, I can not trace which wire is connected to the 2 pin without destroying the connector.
I need an electrical diagram or for someone to look and tell me what the color of the wire is for the 2 pin
Old 07-04-2011, 07:34 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
TB has to come off to remove the inner shield to remove the CPS...
Cheers
Simon
Old 07-07-2011, 09:37 PM
D2Beetle's Avatar
NB Yellow Trifecta
The schematic I have says...
1 - "li/ro", translated violet/red
2 - "li/ge", translated violet/yellow
3 - "br/bl", translated brown/blue
I do believe that simonsi is right.
Old 07-08-2011, 11:25 AM
Thank you. The voltage is 11.06. Can this be my problem for error code P0343 - CPS over limit. I read that the CPS should read 10V. If it is reading 11,does anyone think the CPS is bad?
Old 07-08-2011, 04:32 PM
Toad's Avatar
big poster turned lurker.
Mableton, GA, USA
The car can also throw a cam sensor code if the engine is out of time more than a few degrees (one or two teeth). Take the top timing cover off and line up the dash on the cam pulley with the ot arrow. On the valve cover sheild. Then check the crank pully mark with the arrow on the lower timing cover or the mark on the flywheel and window on the tranny if you have a manual shift.
If the timing is corrrect, all you need to do to get to the cam sensor is loosen the cam gear nut, time the belt back to top dead (ot), release the tension, geet the belt off, remove the loosened cam bolt, remove the cam gear, there will be a woodruff key that might come out DO NOT LOSE IT. Then the sensor is right there being held in with 2 or 3 bolts. Then reverse the process to re-assemblel making sure that the lower and upper timing marks are lined up.
Also note that method does not replace the belt with a new one, or touch the water pump, if it is about that time to replace them, go the full route with removing the mount to get it all off. There's no point of doing the disassembly twice. It.s really not as hard as it seems.
Crank Position sensor replacement dhc8guru 1.8 Liter Turbo 0 11-17-2010 03:14 PM
Position Sensor for Right Linkage Flap Position Sensor (G443) galvatron New Beetle Convertible 1 06-28-2010 03:12 AM
Cam Position Sensor mseifert_99 1.8 Liter Turbo 4 07-03-2009 06:23 PM
MAF sensor testing flip240 Technical Modifications 4 10-24-2006 10:19 PM
camshaft position sensor - CEL sequoiagrapeboy 2.0 Liter Gas 3 02-16-2006 01:16 AM
