Replacing AC Low side service port - NewBeetle.org Forums
Old 07-13-2011, 03:02 AM
Default Replacing AC Low side service port
I have a 1999 2.0L Beetle. I was checking my AC with a set of gauges. When I removed the low side connector the low side valve was leaking. I could not stop the leak, now I will have to replace the low valve. Does any one know how to remove the low side valve correctly. And what is the approximate cost for the part. A friend of mines says he will vaccum and fill the system
Old 07-13-2011, 03:12 AM
savethebluths.org's Avatar
Super smart senior member
Houston,
IIRC it just unscrews. If it does not you will have to replace the entire low side line. Just remember if your system has been discharged for more than 24 hours you MUST replace the receiver dryer.
Need help replacing passenger side mirror ... part numbers, etc. jtown Questions, Issues, Concerns, or Problems with the New Beetle 6 05-18-2012 09:59 AM
Replacing A Side View Mirror? ebt12 Paint and Body 0 05-03-2008 07:31 PM
Need help replacing side mirror ... jtown 2.0 Liter Gas 0 03-23-2008 11:37 PM
Replacing side mirrors to the new model atyp1 Technical Modifications 6 07-03-2007 06:44 AM
Replacing the power lock switch drivers side gumaer 2.0 Liter Gas 6 06-16-2006 02:40 AM
