"V-Checker Basic" Question! - NewBeetle.org Forums
Old 09-17-2011, 06:34 PM
MyOtherRidesAVette's Avatar
Question "V-Checker Basic" Question!
Anyone know if the stored DTC readouts on the V-Checker Basic are in the order of occurance! I would assume them to be, but...
Can't find my instructions.
Thanks,
M.
In der Automobil-Scheune
Old 09-17-2011, 06:42 PM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
Hey, I cannot answer your question directly; as I do not have one of those scanners (I have a vagcom) but you can download the instruction manual here: http://www.ecstuning.com/stage/edoc/VW-Manual.pdf
Old 09-17-2011, 06:48 PM
Thanx!
Old 09-17-2011, 07:05 PM
Well no mention, and no mention of a way to request a timeline or time stamp. Pretty much all Greek to me anyway, however. Lot to learn, I can see. Terminology first.
M.
Old 09-17-2011, 07:31 PM
billymade's Avatar
Las Cruces, NM, USA
Car: 02' Turbo S
I don't know abut the vcheck but the vagcom; checks each computer in a specific sequence and then displays each; then shows any trouble codes association with each sub section of the cars computers. The vagcom doesn't give any indication of "when" the faults occurred; afaik, just that they caused a fault code... I wouldn't think the vcheck would either. On the vagcom; you can do live data while you are driving or car running... that can be shown in graph form... another way to show data.
Question concerning "map" & "maf" sensor giink 2.0 Liter Gas 9 05-12-2011 07:13 PM
FS: V-Checker Basic and UIF-US280 Scan Tool Palmettoguy Parts and Accessories 5 12-11-2010 01:30 AM
Question: ARE BANJO BOLT ALUMINUM "CRUSH" WASHERS LOCATED IN THIS GALAXY? giink 2.0 Liter Gas 9 11-26-2009 04:52 PM
