2.0 engine cooling - NewBeetle.org Forums
Old 09-27-2011, 01:22 PM
Default 2.0 engine cooling
I have replaced the water pump, timing belt, thermostat, cooling fan and everything that has to do with the coolingfans to tell them to turn on. I have also checked to see if there is a blockage in the radiator nothing. the upper hose get hot and hard from pressure and the lower hose is cool to the touch and no pressure. when the car runs the over flow tank starts to bubble and the overheating light comes on. help am lost. thinking it maybe the head or head gasket.
Old 09-27-2011, 01:30 PM
MyOtherRidesAVette's Avatar
You need to purge the air from the system. I'll put that up for you, here, in a minute. If you then still have trouble with your fans, I'll likewise put up the proper way to check them.
Here you go -
Bentley Cooling System Diagnostics
Overheating problem
Bentley drain and fill procedure, follow the directions to the letter. Several short drives, close to home, afterwards, should take care of it. Do not overfill the tank, pay attention to the fill line for cold or the fill line for hot.
Beetle overheating
MORAV
In der Automobil-Scheune
Old 09-27-2011, 02:14 PM
thanks ill try this when i get home this afternoon and i will let you if it works
Old 09-27-2011, 02:31 PM
Thumbs up
It will! Just follow the instructions about the a/c and heat off, 2000 rpm, and whatever else it says. Do check the thread incase someone has something else to add. Dealer Service uses a vacuum pump so they don't have to do this.
Also let us know the fans are operating properly.
M.
Old 09-28-2011, 01:39 AM
the main cooling fan is new. havent done anything to it tonight for the fact that we went and test drove the 2012 beetle.
Old 10-01-2011, 11:38 PM
huck731's Avatar
turbo
Fort Atkinson, WI, WI, USA
Car: black '99 2.0 5spd Retro, 1971 super beetle
have you replaced the sensors that are in the hose head cylinder flange? I had that issue once.
Driver, your New Beetle will see you now.
black '99 5speed "Retro" - Bridgette
kuboto orange '71 super beetle
Bridgette
Huck731
P8121 engine cooling system performance - Bug has a fever? mostasz 2.0 Liter Gas 28 05-26-2011 05:13 AM
Cooling arpster 2.0 Liter Gas 3 07-18-2010 11:18 PM
cooling off with something other than AC? honestfool84 1.9 Liter TDI 17 06-11-2008 06:15 PM
New to Forum and engine/cooling/heater problem sctthrtr 2.5 Liter Gas 38 04-03-2007 05:40 PM
Engine Cooling Problems TxRedBeetle 2.0 Liter Gas 7 03-15-2006 06:31 AM
