Need a tutorial for intake manifold removal - NewBeetle.org Forums
Old 10-21-2011, 01:09 AM
giink's Avatar
Pelham, NH, USA
Car: 2000 VW Beetle 2.0L (AEG)
Default Need a tutorial for intake manifold removal
Does a tutorial/pictorial already exist that explains the step by step procedures for removing an intake manifold from a 2000 Beetle/manual w/2.0 engine? So far I have removed the wiper arms and windshield area cowl and also removed the sort of metal shroud in the engine area against the firewall. I see approximately 3 allen bolts on the front but can't see any rear bolts? Maybe underneath? Anyways, I do want to replace the fuel injectors and I have found a decent tutorial for that procedure.
Old 10-21-2011, 07:08 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
No need to pull off the wipers and cowl. There are 5 allen bolts towards the front of the car and 2 bigger allen bolts on the back side. I just felt them and undid them blind. Go in from the passenger side of the motor and you'll be able to feel them.
Old 10-21-2011, 10:19 PM
giink's Avatar
Pelham, NH, USA
Once you felt the (2) rear bolts... how were you able to access them? From underneath? What specific sort of tool did you use?
Old 10-21-2011, 10:28 PM
giink's Avatar
Pelham, NH, USA
Great Photograph! Could you also explain to me which hoses or parts need to be removed (locations, etc.) so I can lift it out of the vehicle exactly like in your photograph?
Thank you!
Old 10-21-2011, 10:51 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
Just use an L shaped allen wrench and reach around from the back left side of the engine. Can't remember the size for the life of me. Maybe 8mm. I only pulled off the plastic hose for the secondary air pump really then held the intake up with a coat hanger and zip ties hooked to the hood. Here are some pics when I did my spark plugs. I've pulled off the intake completely once and painted one, then 2 other times replacing plugs.
Old 10-22-2011, 05:27 AM
giink's Avatar
Pelham, NH, USA
Nice pics! I may have a few more questions once I begin... ordered the fuel injectors today so maybe in a week or so.
Thank you once again for all of your help,
David
Old 10-22-2011, 01:14 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
You bet. That's what this org is all about. I don't have web access at home so I am not on on the weekends usually. Only Saturday mornings every 2 weeks.
Joel
Old 10-26-2011, 04:58 AM
mltRegistered Member mlt is offline
St. Paul, MN, USA
Car: 2002 GLS 2.0L auto
Would you share a link, please? It is on my todo list.
Old 10-27-2011, 04:51 AM
giink's Avatar
Pelham, NH, USA
All set! Thanks once again for all your help.
David
Old 10-27-2011, 04:54 AM
giink's Avatar
Pelham, NH, USA
Hi Mlt, I used a Haynes Manual specifically for the New Beetle. There's a section on fuel injector removal and installation... no link. But I'd be happy to answer any questions you may have.
David
Old 10-27-2011, 02:33 PM
Opelmania's Avatar
Dubbed Spiderman
Woodstock, IL, USA
Car: 98 2.0 5 Speed
David
NP David! Glad it worked out for you!
Joel
ABD racing manifold intake 1,8T Nashman28 Parts and Accessories 11 05-02-2009 12:52 PM
WTB: stock intake manifold jetta8vwolfsburg Parts and Accessories 4 12-12-2007 02:05 PM
Intake manifold question Friday 1.9 Liter TDI 9 10-16-2007 02:11 PM
Polish that manifold!! Make it SHINE! (tutorial enclosed) bhppy101 Styling Modifications 27 03-31-2007 12:05 AM
ABD Intake Manifold Too Cold NB1.8T Technical Modifications 45 07-11-2006 12:08 AM
