I drove my 98 Beetle for the first time yesturday. It is a Five speed. I kept thinking it was in fourth gear but it was in fifth. At 60 MPH it turn 3'000 rpm's. Is this normal? I would think the little motor would get way better MPG at 2'000??? or so. I drove the car on some city streets when I bought it last week then I loaded it in a car trailer. I never drove it on the Highway. Thanks Dan
Yeah, I found that strange with our 2000 when we first got it, now I'm used to it. I do think the car would get better highway fuel economy if it had a higher top gear....
You could always drive at say 45, you would get real good mileage then. It is normal for RPM for the VW
That was for the benefit of many who ask the same question, concerned something is wrong. If it wasn't normal, what did you think might be wrong? Actually, the way I read your original post, you appeared to be concerned also. And from the sports cars I've owned, and there have been many, speed v rpm seems to be about right on for this size vehicle with this type engine and transmission. I'd have to look at the gear ratio specs for other manufacturers, but would assume them to be about the same.
If you don't know where you're going....any road will take you there. G. Harrison Lily's Pics Gandalf's Pics My Profile Album |
My NB Family... |
You can swap a TDI 5th gear in, which is a common enough thing to do. Otherwise, this is entirely normal and you'll still get good MPGs.
A 5th gear from a TDI tranny with code: DQY, EBJ, or EGR will reduce the RPMs by about 225 at any speed in 5th gear. However, it will not reduce it to the same RPM as in the TDI tranny. Here is why .........notice the differences in the Ring and Pinion Ratios.
O2J Tranny Specs Tranny Codes by engine 1.8 Liter Gas engines (R&P = Ring and Pinion) EBN - R&P 3.684, 5th 0.837 EBQ - R&P 3.938, 5th 0.837 EGX - R&P 3.938, 5th 0.837 EGY - R&P 3.684, 5th 0.837 EHA - R&P 3.647, 5th 0.838 (yes that is correct) ENJ - R&P 3.684, 5th 0.837 FBW - R&P 3.938, 5th 0.837 FBX - R&P 3.684, 5th 0.837 FDS - R&P 3.938, 5th 0.837 2.0 Liter gas engine DZQ, EBP, EGT, EKG, EMS, EZH, FBV - R&P 4.235, 5th 0.837 EFG, ERS, EVR, EGC, EGU, EMR - R&P 3.944, 5th 0.837 2.8 Liter gas engine DZC, EHC - R&P 3.389, 5th 0.844 EZK - R&P 4.235, 5th 0.837 FBY, EWW, FCF - R&P 3.389, 5th 0.844 1.9 Liter diesel engine (TDI of course) DQY, EBJ, EGR. - R&P 3.389, 5th 0.756 Oh, I forgot to add this example: I am currently running a 5th gear from a 2000 NB Gasser Tranny in my EBJ (Diesel Tranny). At about 2700 RPM I am doing 70 MPH........GPS verified and ScanGauge on the RPMs.
2000 Jetta TDI (diesel) 50.1 mpg life-time ave 300,000 miles on 12/28/11 Last edited by AndyBees; 11-01-2011 at 02:41 AM.. Reason: Add comments |
Hey op if it makes you feel any better something similar happened to me. I test drive the bug around a city, never get out of fourth really, I used fifth for a split second just to make sure it works. I buy it. And I hit the highway following my parents on a hour trip home. I had the stereo up and I get up to 80mph and I look down and see this micro tach spinning 4000rpms. I thought oh **** am I in third? So I go for fifth and it seems like I'm there but no way this is right, so I go to fourth and wow. Such a poor gearing choice, these little cars have to spin themselves to an early death because of some boss's sons stupid idea.
If you think that is bad, you ought to drive a VW Vanagon with the Air-cooled engine or the WBXer engine. Depending on the gearing (and there's not much diffence between models), the engine will be cranking about 3600 rpms at 65 mph. It's all about torque and horse power. The MK1 VW diesels are very similar! I've changed the gear ratio in my Vanagon with the TDI engine to slow it down to about 2850 at 65 mph! Any slower will cause Exhaust Gas Temps to go way too high! |
| RPM's | MudBugjr | 2.0 Liter Gas | 22 | 09-08-2009 06:41 PM |
| RPM's at 70 mph? | got-the-bug | Transmission Talk | 6 | 08-07-2009 02:43 AM |
| confused about the rpm's | snoopy041824 | Questions, Issues, Concerns, or Problems with the New Beetle | 11 | 07-16-2008 02:19 PM |
| 89,640 hp at 100 Rpm's!!! | gilligan | Miscellaneous Hoo-Ha Archive | 8 | 04-23-2006 04:23 AM |
| How many rpm's at 60mph? | juhvelo | 2.0 Liter Gas | 14 | 02-10-2006 06:06 PM |
