Supercharger, what do i need? - NewBeetle.org Forums
Old 02-16-2006, 01:29 AM
vdubbugman53's Avatar
Arvada, CO, USA
Default Supercharger, what do i need?
ok so this summer im planning on a neuspeed charger so i was wondering what i need. i plan on getting the smaller pully. also what all comes with the super charger package. Will i need or should i replace the head gasket, fuel pressure reg, etc.? when i do that i take it ill need to run 91 oct. oh and will a 2,5 inch cat back be ok dor this too. i already have a chip. what should i do go back to original or leave the upgrade in.
Thanks
-Nick
Old 02-16-2006, 02:45 AM
FineExampl's Avatar
Poopship Destroyer
Edison, Dirty Jersey, USA
i think it comes with a chip and a few goodies. the $2k or whatever it costs includes alot fo stuff last i checked. neuspeed's site should list the stuff the kit includes. If you find it out, post it.
LOOK AT MY Bug!!!!
Old 02-16-2006, 05:31 AM
BlackBug's Avatar
LocustGroved, VA, USA
Car: 99 GLX 2.0
Befor you do that check this out.
http://www.eiptuning.com/eip/vwa42l8...ystempage.html
It's not WHAT you drive.
It's HOW you drive it!
99 GLX Black 2.0 - 15.992
Old 02-18-2006, 09:54 PM
Arvada, CO, USA
well i hear that the supercharger is a lot more reliable and i really dont want to deal with all the problems the turbo brings. so i was just wondering what people thought about their super charger. ur sig says you have a 2.0 what you got in it to pill a 15.9. now what im really wondering is will i need to do any thing with my head in order to make it work beter with the charger. enging has 57k on it
Old 02-18-2006, 10:11 PM
Arvada, CO, USA
it only says that it comes with a a supercharger P flow chip. my fear is that will up the compression too much and ill end up blowing a head gasket or worse the head
Old 02-19-2006, 01:08 PM
The Cheat's Avatar
overwhelmed/underpaid
New Britain, CT, USA
You make no sense.
A chip isn't going to up your compression. All it's going to do is adjust the air/fuel curve for the supercharger and make provisions so you don't get a CEL.
Once you get the car running on the Nospeed program, try finding an Upsolute rep. I had a custom map on my S/C'ed 2K4 Jetta and I gained 19whp over the Nospeed program.
Neuspeed designs the kit to be 100% reliable at 7 or 9psi. However, if you want more power...you must be brave like I was (and still would be if I had my Jetta).
Mods I would also do if not done already:
-catback exhaust of at least 2.25" in diameter (2.5" is preferred as you're now going FI)
-neuspeed 260 cam (7hp extra) OR techtonics 266 cam/springs (11hp extra)
The supercharger has a lot of reserve...most of it's built into the ultra-conservative programming. Get Upsolute to possibly make you a custom map and you'll be guaranteed to love it.
The kit is complete as can be (right down to a custom P-Flo designed for the charger), so have no fear in terms of needing to buy anything...you won't.
While you're at it, you should do a timing belt as well...you'll have the motor half-apart.
Old 02-19-2006, 04:47 PM
Arvada, CO, USA
yea ill do that and the water pump too as i here those tend to be crap at like 70k. so if i do the upsolute thing am i looking at like another 300 or what? i do plan on doing a cam and a exhaust in time but do you suggest the TT cam and springs or what. if i start getting away from the neuspeed stuff would you say that i will be losing much reliability? i really dont have the money for it to crap its pants all the time.
Old 02-19-2006, 05:39 PM
The Cheat's Avatar
I ran a 266 cam/springs and the custom map since new (put 40k on the car in 9 months).
Never had any problems.
The custom map was a little more than $300, I remember that...I'll talk to my guy who was able to do that. Rocketchip also does custom maps, and I think his map might be way better.
Old 02-19-2006, 09:56 PM
Arvada, CO, USA
ever run a dyno on that
Bahn Brenner Supercharger vdubbugman53 2.0 Liter Gas 6 08-15-2006 12:59 AM
neuspeed supercharger blutopless2 2.0 Liter Gas 7 11-25-2005 09:46 PM
