1998 new beelte not running right - NewBeetle.org Forums
Old 02-16-2006, 10:40 PM
baddassbug's Avatar
baddassbug
sherburne, NY, USA
Car: 1998 2.0 5 speed
Default 1998 new beelte not running right
hi i have a 1998 2.0 5spd and some times when i am driving it will just hesitate and act like it is running on two cylenders, when it is idling and i rev it up it hesatates also have replaced all the sensors and have run injector cleaner i also changed the plugs and wires. any one had this problem, it now has 101,000 miles
Old 02-16-2006, 11:43 PM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
Fuel filter? Thats what it sounds like to me...Or your MAF sensor.
(\__/)
(")_(")
Me: www.myspace.com/beetlenut
Old 02-17-2006, 11:46 AM
Porkchop's Avatar
a.k.a. porkchopzz4
Cartersville, GA, USA
Car: '00 Silver GLS 2.0L auto
is there a CEL? In most cases, engine misfire, O2 sensor, or MAF will throw a code(s).
Old 02-17-2006, 04:48 PM
baddassbug's Avatar
baddassbug
sherburne, NY, USA
lol actually i never thought of the fuel filter its prob that cause i dont think it has ever been changed. but i replaced the maf and both o2 censors and plugs and wires
Old 02-17-2006, 06:01 PM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
Fuel filter should be $12 - $15 bucks and takes maybe 10 minutes to change. Good luck.
Old 02-19-2006, 03:25 PM
speedie's Avatar
Eine Kleine Panzer
Lampasas, TX, USA
Car: 1968 Bug 2001 New Beetle 1.8T 2003 New Beetle 2.0
Also check your vac lines (diagram on the fan shroud)...especially the one to the FPR. Vac lines are the "hidden" probelms for bad ideling. Our lines inside diameter is 3.5 mm.
Old 02-19-2006, 11:57 PM
baddassbug's Avatar
baddassbug
sherburne, NY, USA
ok thanks guys! will have to check them where do i get the tool for teh fuel filter though?
Old 02-20-2006, 04:36 AM
vdubbugman53's Avatar
Arvada, CO, USA
did you check your plugs?
Old 02-22-2006, 04:13 AM
baddassbug's Avatar
baddassbug
sherburne, NY, USA
yeah i check them after it does it but they look fine
Old 02-22-2006, 06:09 AM
Arvada, CO, USA
then id just replace the fuel filter
Old 02-27-2006, 08:10 PM
baddassbug's Avatar
baddassbug
sherburne, NY, USA
i got a fuel filter but got looking at the clamps and they are kinda weird looking has anyone else changed theirs and done it themselves? is there a tool or is it the same as say other brands?
Old 03-08-2006, 02:10 AM
Don't forget to check the vacuum line to the fuel pressure regulator
Old 03-08-2006, 02:15 AM
Oyveychris's Avatar
I love my family!
Knoxville, TN, USA
You have to squeeze them (carefully) then they just pop off. Be careful, the lines are plastic and tend to get brittle. There is a "how-to" thread on the old forum. Good luck! Also pay attention to how the filter goes on, there is an arrow that indicates flow direction.
Old 03-20-2006, 11:24 PM
baddassbug's Avatar
baddassbug
sherburne, NY, USA
ok thanks will try that found my noise it was the heat sheild over the first muffler not the cat! they use those cheap right/nut things and they rusted out. the front two were still on there but the back two let go so the sheild was sittin on the exhaust makin the noise. so i just put two washers and nuts on them and took care of the problem. also i changed my right lower ball joint and ended up having to use a torch to get the nut off, however unfortunatly i hit the cv boot and burned a hole in it so made a 15 min job into a 2 day job!
I am losing oil, and I smell it when the car is running. joshuah 1.8 Liter Turbo 4 01-04-2006 05:55 AM
Daytime Running Lights coinsride 2.0 Liter Gas 6 12-28-2005 05:21 PM
Hot Running Limitwheel 1.8 Liter Turbo 5 11-19-2005 08:21 PM
Day time running lights Duck Technical Modifications 8 10-10-2005 08:16 AM
