Hey e'erybody...
My daughters 04 with 2.0 BEV and AT is throwing the P0221 code as well as the ASR and EPC lights coming on and diving into "limp mode". I have tried the 60 second key on "calibration" and replaced the throttle pedal assembly today. Still throwing the same code and going into limp mode. ![]() What I have learned: The P0221 code is NOT the throttle pedal sensor but a throttle position sensor in the throttle body. (Sensor B) Can anyone steer me in the right direction on how to remedy this problem? Is there a place, other than the stealership, to purchase just the sensors on the throttle body or do you have to buy the whole damned thing? If not, what brand of matches and accelarant would you recommend? ![]() |
By the book -
16605/P0221/000545 - Angle Sensor for Throttle (G188): Implausible Signal Possible Symptoms
Before you go throwing new parts at her Bug in hot pursuit of the trial by error method of diagnosis, you might do well to find someone with Vag equipment, who knows how to use it, and have the Throttle Body Control checked. Curious, what lead you to the throttle pedal assembly replacement. I'm sorry, but when it comes to this component I am clueless other than what is in the book. You need someone who has experience with this particular issue. That said, and trying to say this tactfully, I would be hesitant to give you the part number, or sourcing for same, as I'm afraid you'd just continue your T & E diagnosis. Part of the reason for your "what brand of matches and accelarant would you recommend?" comment, which by the way IS funny. As regards the ASR and EPC Warning lights. these are two different systems. The EPC monitors the engine control system and alerts you of a malfunction and at the same time throws the engine into limp mode, what your are experiencing (see the bottom of the attachments below). The ASR is the anti-slip function of the traction control and is also explained in the last attachment(s) below from the '04 Owner's Manual. More from the book - .
In der Automobil-Scheune '02 NBT, A/T, Moonroof, Platinum Gray, Flannel Gray Leather Interior (Currently on the slab in the morgue, possible ressurection in the offing) '05 NB Convertible, Tip 6sd, Dark Flint Gray Edition, Garnet Red Top, Bordeaux Red Leather Interior '01 Corvette Convertible, Magnetic Red, Light Oak Top, Light Oak Leather Interior '96 Suburban LT 2500, 454BB, Summit White, Neutral Leather Interior '95 Camaro Z28 Convertible, Polo Green, Black Top, Tan Leather Interior Last edited by MyOtherRidesAVette; 12-03-2011 at 05:04 AM.. |
Here is a link to the Vortex on how to remove and clean a TB on a 2.0 Sorry, forgot to post the link http://www.vaglinks.com/Docs/VW/MKIV...eaning_DIY.pdf Last edited by IndyTom; 12-03-2011 at 02:06 PM.. |
Weeellll, what led me to replacing the pedal assy was a generic code reader and some bad advice through another board.
There are four sensors involved in throttle position (2 on the TB and 2 on the pedal assy). The "VW Tech with over 30 years experience" that gave the aforementioned advice said the pedal assy fails often. I am definitely not a T&E mechanic, however, my previous foray into VW's was an air-cooled, 2108cc, 1970 Baja about 25 years ago. My frustration with this vehicle is that it has spent almost as much time parked over the last 8 mos as it has on the road. New A/C compressor, New valve body in the transmission, and 3 trips to the stealership for a wiring issue that killed the bulbs in the Headlamps, DRL's, foglamps, all four turn signals, and park lamps on the front at the same time. I bought it with 36k on 2.5 years ago. |
Sorry to hear you are having so much trouble with it. But I guess after all this time I wouldn't give up. You probably got most of the bugs out of the bug. ![]() Here is the link on how to clean the TB on 2.0l MKIV vehicles: http://www.vaglinks.com/Docs/VW/MKIV...eaning_DIY.pdf |
And that's the first I've heard about the pedal assembly. Granted, I have only been really involved in VWs for 7-8 years, not 30, but I was on this forum and other VW forums, for those years and had my car for 6 1/2 years. I don't think I ever once heard of a pedal assembly failing. Stick with these boards ![]() Also, I'd take a look at what MORAV posted. The Ross-Tech wiki he posted from is always my first source when looking for code info. Followed by the Bentley (which he posted images from). If you are doing a lot of DIY work, I'd suggest picking yourself up a Bentley manual. Great tool to have and worth every penny. Plus, the holidays are here...maybe put it on your wishlist ![]()
I don't want to start some sort of inter-board war, but, the initials of the other board are...
...vwvortex.com... The guy I had been pm-ing with has "ASE VW Tech for 30 years" in his bio and has provided me with some sound advice in the past. That is the really frustrating part. Tomorrow, I am going to pull the throttle body and clean it... I am not familiar with Vag-Com and live in an area with limited resources for that type of tinkering, unless, of course, it is used in John Deere tractors. I will stick with these boards. There's something to be said for folks who will post their solutions out in the open for everyone to read, rather than via pm. I will keep you guys posted on the progress. |
![]() Quote:
![]() Must be a full moon ![]() |
I was never suggesting you had received bad advice, just wanted to know what lead you to the pedal assembly. I think you were given sound advance, from someone, who I believe was being honest in their credentials, and probably has more experience than half the members here put together. Probably the same path I would have taken, and when that wasn't the resolve, I would have probably gone back to that same person for further direction. There is as much bad advice and direction given on Forums as there is bad/faulty work done by those who work on cars for a living and attempt to repair VW products without the proper training and/or the proper diagnostic tools. People come to Forums seeking advice/solutions because 1) they don't want to spend the money or 2) they don't have the money, to have their car properly diagnosed and repaired by a shop and/or mechanic who is qualified in this type of thing. Many come here, and to other Forums, with problems, either poorly stated, lacking all, or enough detail, or with codes read by generic code readers, and expect miracles in obtaining immediate and perfect resolves. There is a reason, shops don't do repairs based on just what the Owner says. Instead they take this as a general direction in which to look and then spend time, some times a lot of time, doing the proper diagnosis. Sometimes charging for this service that outrages many. Many who think it is as simple as plugging a reader into the OBD port, ordering a part, and installing it. Not true, many diagnostic procedures take way longer than the actual time involved in installing the new part or fixing the problem. But yet people whine, and cry, and are outraged at charges for this, and instead turn to the Forums, seeking advice from those with limited knowledge, limited resource, and working with a limited amount of knowledge. I am especially outraged by those who want to run down to the Corner Auto Parts and expect these people, many times kids working a part time job, with no real training, and even less experience, who expect these people to run right out to the car, with generic, base, equipment and in five minutes do a proper diagnosis, define the exact part failure, and then in turn run home, jump on line, find the cheapest online part they can, order it, put it in, and find it isn't the problem. And then are totally perplexed, and pi$$ed as to how this could possibly have happened. "That damn Corner Auto Parts Store" or in this case "That damn other Forum". People, you get what you pay for! When you pay for nothing, anything you get beyond nothing, is a gift! In your case, from all I understand, and I am no expert, or trained technician, the components involved in your specific situation can all be diagnosed the Vag equipment. Not just done by reading a DTC from this equipment, but rather asking the right things of the equipment and then properly interpreting the equipment's response(s). M. |
Throttle-body replaced, assimilated and running perfectly!
I leave you all with a final note for this board...and vwvortex... MORAV, I have said nothing negative about VWVortex in toto, I was simply answering the question asked of me...my dissatisfaction stems from the info I received from someone who states he is an ASE-Certified VW Tech with 30 years experience. I provided the same info to this board almost verbatim and received puzzled inquiries as to what led me to the pedal assembly. No one here has claimed ASE certification or any other credentials, yet the information provided has been infinitely more accurate. For that I salute you, SB, and IndyTom. Admittedly, I do not have much skill in diagnosing OBDII issues. As I stated in an earlier post, my experience is largely rooted in pre-OBD vehicles. (1970 Beetle, 2 x 1966 Ford Mustangs, 1958 Chevy Apache SWB Custom Cab, 1968 Camaro RS/SS 396 w/ 871 GMC blower that ran 9.08-second quarter-mile at 164 mph, and, yes, 3 x 'Vettes: 63 Coupe, 66 Conv, and 68 Conv.) However, I am capable of pulling my own codes, with my own OBDII reader and researching the causes for the trigger of that code. In cases where the service manual is ambiguous, I have resorted to the boards for help. Usually, I find enthusiasts who are knowledgeable and friendly. Never have I relied upon the retail counter help (full- or part-time) for advice. As a healthcare provider, I am responsible for the lives of others on a daily basis. I am as meticulous in my garage as I am in the research, preparation, and execution of a plan of care. You will recall from the first post on this subject that the car belongs to my daughter. That in and of itself should have been enough to quell any thoughts that I would be half-assing this job! I am "especially outraged" by self-righteous pricks who think they are the only one who possess the knowledge and skill to perform ANY task...without EVER having to have learned anything from any external source. To quote Will Farrell in Elf, "You're an angry elf!" |
| Tail Lights not working after replacing Brake Lights | megepo0 | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 05-21-2011 12:04 PM |
| Interior Lights/Clock/Licene Plate Lights | kellar91 | Questions, Issues, Concerns, or Problems with the New Beetle | 2 | 04-24-2011 04:42 PM |
| EPC, ESP dash lights on and no brake lights working | beetlecab06 | Questions, Issues, Concerns, or Problems with the New Beetle | 1 | 04-14-2011 07:35 PM |
| P0221 | FreqWiz | 1.8 Liter Turbo | 6 | 03-10-2011 12:29 AM |
| Pepboys - grrrrrr | madjalapeno | Market Place Archives | 10 | 02-06-2006 03:21 PM |
