Check Engine Light Mystery - NewBeetle.org Forums
Old 12-03-2011, 06:01 PM
KY, USA
Car: 2001
Default Check Engine Light Mystery
Ok,
2001 VW Beetle and the check engine light keeps coming on and going off later. My theory is it keep sgoing on if the heat is on 'full heat'. When it is not all the way to the max heat setting it doesn't seem to come on. The light will come on and then about 100 miles later go off. Took it to autozone when the light was on to have the code read and it said 'no diagnotic information'. Was going to take it to a mechanic (and pay to have it read), but it went off. Any ideas?
Thanks!
Old 12-03-2011, 06:57 PM
If its been on, there will be a code. Take it somewhere that has a better code reader. The CEL doesn't have to be on for there to be a code stored.
Brake Light, Check engine light, air bag light, but wait theres more djack19 Questions, Issues, Concerns, or Problems with the New Beetle 15 11-09-2011 10:13 AM
check engine light came on..engine threw 10 codes. jbremount 1.8 Liter Turbo 4 09-16-2011 02:38 AM
ABS Light / ESP / Check Engine Light Strangness purduecmpe 2.0 Liter Gas 5 03-21-2011 07:04 PM
Check engine light/Cold light periodically bulldoggergal Questions, Issues, Concerns, or Problems with the New Beetle 8 12-17-2009 10:36 AM
2001 glx + awp engine swap = check engine light!?! NEED HELP garvitron 1.8 Liter Turbo 7 05-07-2009 12:22 PM
