Hello again,
This time I am ready to replace one of my fog lights as the reflector is gone to pieces. Doing a search I find that there are 2 schools of thought on the process, one seems to indicate that I have to take the entire front clip off the car to replace 'em The other shows just the grille being taken out to replace the lights. Which is correct for a '99 2.0? Thanks! J T |
When I replace my daughter's fog like on her 2002 and it might be the same as yours. I didn't take the front clip off, you should see a seam where the front grille is separate from the front clip. I don't even think I took off the grille.
If I remember correcty, I took off the plastic skid plate off of the bottom of the car and that makes it so you can access them from the rear. I remember installing them from the rear. Start by taking off the skid plate and you should be able to figure it out if yours is like my daughters. JR |
sounds like something I don't want to do unless there is a zipper holding the thing on. Wish I'd asked before ordering the replacement lights.Thanks tho' J T |
You might have a look at yours, several parts catalogs show the valence as a separate piece '98-'02, the bar with the fogs is also shown as a separate item. I can't verify that the '99 looks like this - ![]() But if it does, here is the DIY, courtesy MichelleRoze How to: Easy fog light bulb change/fog light assembly removal Reviewing some Photo Threads of other members, hard to tell but it appears to be a separate part on this '98 ![]() And it would certainly appear to be separate on Opelmania's '98 (who obviously can walk you through the R&R!) ![]() Actually looks like a pretty easy, straight forward project! Assuming yours isn't one of those Canadian models where they molded the fog valence into the bumper. M.
In der Automobil-Scheune '02 NBT, A/T, Moonroof, Platinum Gray, Flannel Gray Leather Interior (Currently on the slab in the morgue, possible ressurection in the offing) '05 NB Convertible, Tip 6sd, Dark Flint Gray Edition, Garnet Red Top, Bordeaux Red Leather Interior '01 Corvette Convertible, Magnetic Red, Light Oak Top, Light Oak Leather Interior '96 Suburban LT 2500, 454BB, Summit White, Neutral Leather Interior '95 Camaro Z28 Convertible, Polo Green, Black Top, Tan Leather Interior Last edited by MyOtherRidesAVette; 12-07-2011 at 10:37 AM.. |
I have a 2000 VW Beetle and the grill part can not be removed. Not sure when they finally got smart and put in those removable grill fronts. That said the fog light assemblies are held in by 3 screws so if you jack up the car you should be able to remove them. However, I did change the bulb on my drivers side fog light and that was pretty easy.
I just looked at the thread that Michelle posted. WOW, I wish it were that easy. They must have changed that design in either 2001 or 2002. I guess the 1998 to 2000 Beetles are just SOL. Last edited by IndyTom; 12-07-2011 at 04:41 PM.. |
Maybe you got one of them Canadian versions too! ![]() ![]() |
As per Marvins_dad Post number 2 of Michelle's DIY thread above: "Just a note - Pre mid 2000 models still require the old method of taking off the bottom skid and possibly removing the front end. That's just because the grill can't be removed the same way from what I recall." Now, if you are just changing the light bulb you can still do it without taking off the bumper but if you need to replace the entire fog light assembly it will be very tough. My driver side log fog light mount is busted and I zip tied it as per advise from Opelmania. So far so good. |
Tom-> I tried every little bit to try and get in there, just too small an area height wise. Even have 90 degree screwdrivers that won't work. German Engineering...Gotta love it! ![]() |
MOD 101. Zip ties and Duct Tape hold the world together ![]() |
Btw, thanks for allowing me to pirate your pic and use you as an example! ![]() |
Something like this: |
Maybe just the screw tip on the end of a pair of vice grips. Can't think of anything else that would require less clearance. Problem may be clearance as the screw unwinds. Gonna be a bitch! Looking closer it appears to be a "slide in", just need to loosen the screw head not take it out. This is good because getting it back in could be a real challenge! lol it's a pan head, so you may be able to turn the screws with just a small vise grips.
| How to replace bumpers lights...?? | s_santiago | Styling Modifications | 34 | 04-21-2012 03:50 PM |
| How do you replace the Reading/Dome Lights? | Bert336 | Technical Modifications | 1 | 05-18-2010 02:13 AM |
| How to: Replace your license plate lights | callisto9 | 2.0 Liter Gas | 8 | 07-29-2009 02:41 PM |
| ASAP HELP!!! Brake lights out...how do you replace? | bugdreamsdocometrue | 2.0 Liter Gas | 1 | 01-19-2007 04:34 AM |
| Tail lights in 2006 - how to replace? | anna_k | Questions, Issues, Concerns, or Problems with the New Beetle | 3 | 09-02-2006 10:05 PM |
