OOPS.....i need an intake plenum - NewBeetle.org Forums
Old 12-09-2011, 08:55 PM
Default OOPS.....i need an intake plenum
I broke (cracked open BAD) the ijntake plenum on my 2003 AEG...did anyone else know these things are plastic? and does anyone have one to sell me? ive seen em for other vw's for as little as 50 bucks....but dont think it would fit an aeg engine.
HELP!!!!
Old 12-09-2011, 10:51 PM
AndyBees's Avatar
USA, USA
Car: VW Jetta TDI
Default Location of break
HELP!!!!
Is it broken where a bolt goes thru?
If not, you may be surprised what JB Weld will do. I'll give you two examples:
1. I repaired a Briggs two-cylinder engine in 2001 with JB Weld. The cam broke and pieces punctured the side of the lower housing. That engine still runs today on a saw with no leaks .......it's air-cooled and heats up considerably.
2. Lots of folks have successfully used JB Weld on TDI oil pans. They are cast aluminum and crack easily if the car bottoms in a bad pot hole.
Clean the area with Carb cleaner, blow off with compressed air and then apply the JB Weld. Use a C-clamp or something similar to hold in place until cured!
2000 Jetta TDI (diesel)
50.1 mpg life-time ave
300,000 miles on 12/28/11
Old 12-10-2011, 03:25 PM
LOL.....no it has a BIG hole in it (like 3 inches round) ...it definitely needs replacement....we had the hood off to straighten out some issues with the left front body lines (my 2003 NBC is a rebuild) and a 3 lb mallet tumbled off the top of my stack box....didn't damage anything else...btu the plenum is beyond repair....well, i won't say that....it is beyond repairing to any semblence of factory .... sure i can patch it up adn keep it running as if nothing is wrong...i may even just fiberglass it...but it'll still look like a hack job til i replace it.
Old 12-10-2011, 04:35 PM
I have some AEG manifolds I'd sell cheap. Post a pic of your broken one.
Old 12-10-2011, 08:13 PM
cool ...min is an AEG...i will try to post pics in the AM.
Scotch-brite pad oops aj1140 New Beetle Detailing/Cleaning 4 03-24-2011 03:17 AM
2001 beetle 2.0 making noise in intake plenum dweave3 2.0 Liter Gas 4 02-02-2010 12:23 AM
Ghostride Racecar driver - Oops! dnyed Miscellaneous Hoo-Ha 5 12-25-2008 02:56 AM
Oops She did it again! AmyJane Miscellaneous Hoo-Ha Archive 54 02-19-2007 05:39 PM
inner plenum covers removing montague Questions, Issues, Concerns, or Problems with the New Beetle 3 06-23-2006 12:53 PM
