Back again with more issues, lol. So my little sister calls me and says that her car isn't running. After getting it to my work, I find that it will start, rev to 2k, and immediately die. Only way to keep it running is to keep foot on pedal. Did notice that if I barely hold the pedal it will suddently rev all the way to redline until I remove foot. CEL on, codes PO440, and P0455. Emission codes that have been there since we got it (N80 valve). No vacuum leaks that stand out. Disconnect MAF and vehicle will idle on its own along with small backfires through intake. Replaced with a new Bosch MAF and same problem occurs. Did notice connector to MAF isn't in perfect shape, the red plastic portion of inside connector is missing, (might be problem?), Plugs and wires have been replaced along with new timing belt, tensioner, and water pump. No battery issues prior to this problem either. HELP!
Both codes are pointing to your EVAP system.
What engine/trans in the car? How many miles?
Both codes have been in the system for months with no prior issues. AEG/auto 2.0L 160K. Sister stated that vehicle was fine, parked it for a few hours, came back to car and it started to stall after starting.
Update, Have ground and 5V reference at MAF connector, and I have 12V on blue/yellow wire for a couple of seconds when key is turned on. Last edited by Sissy's_Beetle_Bug; 12-12-2011 at 04:25 PM.. |
| Random Stalls | pfeifervw | Questions, Issues, Concerns, or Problems with the New Beetle | 15 | 02-09-2011 12:51 AM |
| 1999 1.8T stalls | TOMMYD | 1.8 Liter Turbo | 2 | 07-29-2010 08:19 PM |
| Starts and Dies, 10 minutes later Starts for good. | jarobert | 1.9 Liter TDI | 11 | 01-16-2010 12:03 PM |
| Cyc Misfire, ASR, ESP, stalls Help plz! | P944 | 1.8 Liter Turbo | 12 | 05-27-2009 03:28 PM |
