Airbag light comes on when... - NewBeetle.org Forums
Old 01-07-2012, 11:23 PM
giink's Avatar
Pelham, NH, USA
Car: 2000 VW Beetle 2.0L (AEG)
Default Airbag light comes on when...
Every time my wife drives the Beetle, she needs to move the seat up and when she does the airbag light comes on. I can turn it off with my scanner but the next time she drives it and moves the seat up again it will come on. Can anyone here possibly explain what is happening and if so... any pics of what I can do to fix this annoying problem???
Thanks
Old 01-08-2012, 12:41 AM
D2Beetle's Avatar
NB Yellow Trifecta
Springfield, TN, USA
Off the top of my head, tt sounds like you have a loose or broken wire under the seat. This thread might be helpful.
My NB Family...
Old 01-09-2012, 12:05 AM
Very common problem. Just check under the driver seat there's a pair of wires goes from seat into floor after many times fold the wires get broken. Simply use some wires connect(and better solder) them the problem will be gone. Suggest you disconnect battery and discharge airbag before doing it since airbag might deploy if you did something wrong.
Thanks
Old 01-10-2012, 04:06 AM
giink's Avatar
Pelham, NH, USA
Thanks guys... I will check it out.
HELP Check Engine light and Airbag light is on littledeed Questions, Issues, Concerns, or Problems with the New Beetle 1 12-31-2011 06:03 PM
Airbag light is on Casper 2.0 Liter Gas 1 09-07-2009 11:21 PM
2000 beetle driver side airbag resistance too low - cluster airbag light turbobugger Questions, Issues, Concerns, or Problems with the New Beetle 2 07-22-2008 10:14 PM
Abs light plus airbag light on at same time. SALTYDOG1960 1.8 Liter Turbo 0 01-01-2008 08:16 AM
