replacement head info - NewBeetle.org Forums
Old 01-16-2012, 11:33 PM
fast86gn's Avatar
First Time Away From GM
Plattsburgh, NY, NY, USA
Car: 99 GLS
Default replacement head info
Im looking to buy a replacement cylinder head. the car is a 99 beetle with 2.0l. the local shop is behind and I dont want to wait a month. why do some ebay listing show the beetle and golf are the same, while others show they will not interchange? Any help will be great.
My Car 1986 Buick Grand National
Daughter has 99 Gls 2.0 with 5 speed
Old 01-17-2012, 12:15 AM
The only thing you have to make sure is the engine code. A '99 beetle 2.0L engine code is AEG so you have to search for a head for AEG engine that's it. It doesn't matter with car model. Some years of Gold, Jetta, and New Beetle all have 2.0L AEG engines.
Old 01-17-2012, 11:57 AM
fast86gn's Avatar
Car: 99 GLS
ok thanx. Im see some listed with casting numbers. Im unsure if I have the correct numbers. Does 037AD sound correct? If I just match up that is that enuff? Thanks again, still searching.
Old 01-17-2012, 03:45 PM
I have one! $220 shipped to you with a spare set of lifters sound good? The last head I shipped to the US cost me $80 so it's $140 plus shipping basically. This head is bone stock, it originally came off my 2000 (06/99) AEG Beetle.
Old 01-19-2012, 01:32 AM
I got a rebuilt 2.0 (AVH) head from these folks about 3 weeks ago.
J & C Enterprises - Fairmont, WV - Cylinder Heads
Picked-up for about $200 plus my exchange. They also ship.
They wanted to know the head casting number (above the #1 intake port) and if it had EGR ports (about 1/4 dia holes below the echaust ports).
You will need to remove and reuse the cam gear, all of the studs from your old head (intake, exhaust, valve cover, and tensioner) as well as the oil plug near the water outlet (opposite the cam gear). You also need to install a new cam seal.
Low Fuel Pressure After Head Replacement 2005 NB POS Questions, Issues, Concerns, or Problems with the New Beetle 1 11-04-2011 04:43 PM
Head Gasket Replacement Dyspnea 2.0 Liter Gas 4 01-23-2011 04:21 PM
Head Gasket replacement jic1997 2.0 Liter Gas 5 10-18-2008 10:44 PM
1.8 Turbo head replacement oldaudiguy 1.8 Liter Turbo 2 05-04-2008 02:58 PM
how hard is DIY cylinder head replacement? jknoche5 1.8 Liter Turbo 1 06-07-2007 10:37 PM
