Secondary Air Injection Pump - NewBeetle.org Forums
Old 01-19-2012, 02:29 AM
Default Secondary Air Injection Pump
Where is the Secondary Air Injection Pump Relay located? We are getting a code of P0411. Pump works we have tested it! Can't find the relay! Any other suggestions would be greatly appreciated
Old 01-19-2012, 02:00 PM
If it works, that relay should be fine. Could be your fuel pump relay, or a number of other things.
16795/P0411/001041 - Ross-Tech Wiki
16795/P0411/001041 - Secondary Air Injection System: Incorrect Flow Detected
Possible Symptoms
Malfunction Indicator Light (MIL) ON
Possible Causes
Fuel Pump Relay (J17) faulty
Hoses/Pipes to/between Components faulty/clogged
Secondary Air Injection Pump (V101) faulty
Secondary Air Injection Pump Relay (J299) faulty
Secondary Air Injection Solenoid Valve (N112) faulty
Possible Solutions
Check Fuel Pump Relay (J17)
Check Hoses/Pipes to/between Components
Check Secondary Air Injection Hoses/Pipes for Carbonization
Check Secondary Air Injection Pump (V101)
Check Secondary Air Injection Pump Relay (J299)
Check Secondary Air Injection Solenoid Valve (N112)
Old 01-19-2012, 11:00 PM
simonsi's Avatar
Jitterbug
Auckland, New Zealand
Car: 2000 NB 2.0
Air leak at the pump or its hoses, the error comes from the wrong chemistry in the exhaust despite the pump being commanded to run so if the pump physically runs (which shows the relay must be ok...), then the air produced by the pump is escaping from the pump or hoses and not getting into the exhaust...
Cheers
Simon
Old 01-20-2012, 02:35 AM
That was my assumption as well.
You pump could be pumping fine, but if it's leaking you're gonna throw a code.... It happened to me.
Don't know the year of your beetle (fill our your user profile- what we see in the upper right hand corner of your posts. It helps us help you), but if it's an earlier model, namely a SAI Pump with rivets, it an easy DIY repair. Basicially drilling out the rivets and replacing them with machine bolts and nuts. Pop the SAIP back in and you're in business.
CLICK HERE FOR THE DIY REPAIR THREAD.
Before you start your beetle, pop open the hood. Next, start your bug, then go under the hood and put your hand around the SAIP, if you feel air blowing/sucking around the seams, that's your problem and need to do the repair.
Hope this helps
WTB : Secondary air injection pump socalbulldog Parts and Accessories 5 02-19-2010 06:21 PM
WTB: Secondary Air Injection Pump FallinApartBoy Parts and Accessories 2 01-26-2009 05:34 PM
Secondary Air Injection Pump chris22104 Questions, Issues, Concerns, or Problems with the New Beetle 2 01-18-2009 07:34 PM
Secondary Air Injection Pump aaeemg Questions, Issues, Concerns, or Problems with the New Beetle 4 03-19-2008 12:05 AM
Secondary air injection pump slvrbtlboi 1.8 Liter Turbo 7 03-09-2008 12:22 AM
