I have a 2000 vw beetle currently with engine block light on and airbag light
ive had the cam belt and sensor changed but still the light is on, the airbag light mysteriously came on when an rac guy changed the ignition switch so im not sure if he has dislodged a wire under the dash or the driver seat. the errors shown are airbag igniter driver side,N95 resistance too low? And the 17990 code states idle adaption limit reached. Anybodt have some advice on this i would be extremely grateful for the insight. thanks matthew |
For the 17990 I'd start with a TB adaptation. And the airbag code...looks like you need to be VERY careful when addressing it, as it deals with the igniter. Otherwise, here is info:
17990/P1582/005506 - Ross-Tech Wiki 17990/P1582/005506 - Idle Adaptation Limit Reached Possible Solutions Check Fuel Pressure Check Intake System for Leaks (False Air) Check Fuel Injector(s) Check Evaporative Emission (EVAP) Canister Purge Regulator Valve (N80) Check Exhaust System for Leaks Check Secondary Air Injection (AIR) for Leaks Check Vacuum Lines for Leaks Check Throttle Body --------------------------------------------------- 00588 - Ross-Tech Wiki 00588 - Airbag Igniter; Driver Side (N95) 00588 - Airbag Igniter; Driver Side (N95): Resistance too Low 00588 - Airbag Igniter; Driver Side (N95): Resistance too High 00588 - Airbag Igniter; Driver side (N95): Short to positive 00588 - Airbag Igniter; Driver side (N95): Short to ground Possible Symptoms Airbag Warning Light active Possible Causes Wiring from/to Airbag Igniter Driver Side (N95) faulty Coil Spring with Slip Ring (F138) faulty Airbag Igniter Driver Side (N95) faulty Possible Solutions Check Wiring from/to Airbag Igniter Driver Side (N95) Check Coil Spring with Slip Ring (F138) Check Airbag Igniter Driver Side (N95) Special Notes When "Short to positive" or "Short to ground" is found, DO NOT CLEAR THE DTC. This can cause the airbag to deploy. See repair manual for more information.
Check the wires under the driver seat. 80% airbag codes are due to the cracked wires under driver seat.
The idle adaption limit code is quite easy just clean throttle it will be gone. Quote:
| Engine errors:00588 and 17990 Help!! | mattbug | 2.0 Liter Gas | 0 | 01-21-2012 11:18 AM |
| check engine light came on..engine threw 10 codes. | jbremount | 1.8 Liter Turbo | 4 | 09-16-2011 02:38 AM |
| WTB Beetle with blown engine or severe engine problems | gale1221 | New Beetle Classifieds | 0 | 08-26-2011 02:00 PM |
| 2001 glx + awp engine swap = check engine light!?! NEED HELP | garvitron | 1.8 Liter Turbo | 7 | 05-07-2009 12:22 PM |
